Ford 8.8 Rear Axle - Page 4 - JeepForum.com
post #46 of 47 Old 04-23-2012, 11:04 AM
jhughes2013
1977 CJ7
Originally Posted by LT1CJ7
Your pushing the limits of it.
The 8.8 has some common failures with twisting the axle tubes "plug welds"
C-clips and snapping axles when in the rocks.
The added horsepower & lower crawl ratio only adds to the stress.
The good thing is if the tubes are welded and you add the super88 kit, You should be okay.
Tubes have already been welded. Super 88 is on the list, but a cut down front D44 is the next upgrade.
'77 CJ7, LS1, NV4500/D300, Ford 8.8, 4" of lift, 33x12.50 BFG ATs...
jhughes2013 is offline
post #47 of 47 Old 04-23-2012, 11:16 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
There ya go!
sounds like you have done some research.
I'd check on some chrome moly shafts and some ctm or like joints for the front D44 as they are the weaker point.
I'm also running a front D44 pushing 400 HP LT1 and have put some pretty good beatings to it without failure.
My intentional weak point are my lockouts.
lifetime warranty and only a 10 min. Trail repair.
LT1CJ7 is offline
8.9 , axle , cj , ford , rear axle
Disk Brakes on Ford 9" rear axle ? Bud Jeep CJ Forum 11 10-19-2010 06:29 AM
Ford 9-inch rear axle strength I6CJ7 Jeep CJ Forum 6 05-11-2010 07:21 AM
Ford 3/4 ton Axle Swap R0J Jeep CJ Forum 4 04-06-2009 02:50 PM
Ford 9 inch Rear axle jeepthing360 Jeep CJ Forum 4 10-12-2006 09:28 PM
80 Cj what front axle to match ford 9" rear? silver_2000_TJ Jeep CJ Forum 3 03-31-2005 06:42 PM
