Ford 8.8 Rear Axle - Page 2 - JeepForum.com
post #16 of 47 Old 04-21-2012, 06:45 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by LT1CJ7
The Explorer 8.8 is 60.5" wide.
The narrow track AMC 20 is 50.5" wide.
That's a hefty 10" difference.
What's your plan for the rear driveshaft & C-clip eliminator ?
I think we're both correct. The number I posted is the Ford "track width" (or it's something close to that) and I believe the number you posted is the WMS to WMS (Wheel Mounting Surface) dimension.
Either way, the Explorer axle is wider. But maybe not 10" wider? The YJ Wrangler factory listed "track width" is in my FSM as being 59" wide. I have transplanted several 8.8 Explorer axles into YJ Wranglers and they are 5/8" narrower (on each side, 1-1/4" overall) than the stock Dana 35 YJ Wrangler axle.
I'm not arguing, just wondering if there's really 10" of difference in width.
I've never done the research for a head-to-head comparison between the two, and my old fart memory is likely to be off a little on the exact numbers.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #17 of 47 Old 04-21-2012, 07:34 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Correct, I listed wms-wms
The Explorer 8.8 is 10" wider than a narrow track CJ AMC 20 rear axle.
The NT AMC 20 is in 1976-1983 CJ5's and 1976-1981 CJ7's
1982-1986 CJ7's came with wide track axles.
You are correct on a near perfect fit when swapped into a YJ.
But the 8.8 isn't a great swap into a CJ, Let alone a NT CJ.
LT1CJ7 is offline
post #18 of 47 Old 04-21-2012, 09:54 AM Thread Starter
thartleystj
They make an adapter for the driveshaft and it has disc brakes so you really do have to worry about the c clips. Also I really don't think it's that wide because I know a few people who have a ford 8.8 in the rear of a cj5 and it's not bad at all. I'm using a Dana 30 wide track front axle and I was just trying to come close to having the same width
1999 Jeep Wrangler TJ
4" Lift Kit, 20" XD Rockstars w/32" Nitto Terra Grapplers
thartleystj is offline
post #19 of 47 Old 04-21-2012, 12:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Good info that's good to know!
Aside from the width issue, the wheel bolt pattern difference adds to the lack of compatibility.
Now if you could find an old Lincoln Versailles 9 incher laying around, that would be worth looking at.
Max
Mean Max is offline
post #20 of 47 Old 04-21-2012, 12:29 PM
98blacksahara
1951 CJ3A
Max
Except that the 9 inch has one of the lowest pinions of any axle. It makes for worse driveline angles and will drag over everything in the rocks
Originally Posted by RubiconRazorbac View Post
Well, I've never eaten a turd sandwich, but I wouldn't have a problem recommending not to try it.:thumbsup:
But I'm sure someone out there will post that they regularly eat turd sandwiches with no problems...
98blacksahara is offline
post #21 of 47 Old 04-21-2012, 12:41 PM
digger21
That's an issue but thousands of rock crawlers use em, including me. The ford 9 is a sick axle and I'll use it over a 44 or 8.8 any day. If you're gomna use 35+ tires than the LP won't matter anyway
digger21 is offline
post #22 of 47 Old 04-21-2012, 12:50 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Unless you're on an unlimited budget, then there's this.
http://www.truehi9.com/
Max
Mean Max is offline
post #23 of 47 Old 04-21-2012, 12:55 PM
98blacksahara
1951 CJ3A
Max
For an unlimited budget, I'd have a high pinion 609 or portals...
post #24 of 47 Old 04-21-2012, 01:20 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Does the adapter just bolt in with no need to shorten or lengthen the drive shaft itself ?
If it has discs, then it shouldn't need an eliminator kit, as the calipers will keep the axle forme coming out if there is a failure.
The Ford Explorer 8.8 is 60.5" wide when measured WMS-WMS !
A WT AMC 20 is 54.5" WMS-WMS !
A WT Dana 30 is 56" WMS-WMS !
The 10" difference is from a NT.
There was no mention of using a WT up front.
Think what you want, Those are the specs.
To make it close to equal width, you would need 2" wheel spacers for the front.
Also as mentioned, what's the plan for the rear bolt pattern ?
LT1CJ7 is offline
post #25 of 47 Old 04-21-2012, 08:09 PM Thread Starter
thartleystj
For the rear bolt pattern Superior Axle and Gears makes a kit call the Super 88 Kit that changes the bolt pattern over to a 5 on 5.5 as well as upgrades the axle shafts which is what will have to be done for this axle for everything to match
post #26 of 47 Old 04-21-2012, 08:36 PM
scottymac62
1979 CJ7
Moser Engineering will also re-drill your axles to 5x5.5 for a modest fee.
Moser Engineering
102 Performance Drive
Portland, Indiana 47371
260-726-6689
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #27 of 47 Old 04-21-2012, 10:00 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Oh, okay.
I didn't know you were adding a $600 kit.
LT1CJ7 is offline
post #28 of 47 Old 04-22-2012, 10:47 AM
papa355
1977 CJ7
so what is your grand total $$$ for this 8.8 swap up to?
I have never done a 8.8 swap, and after reading all the post the last couple of days on how much it cost to make a 8.8 work......... i will never do one, nor would I ever recommend it........lol. (I mean come on an axle out of an exploder?)
Another thing, just cus it has disc brakes..........doesn't make it a good axle. What holds the axle in on a disc brake 8.8? Is it still a c-clip? (I am just asking)
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #29 of 47 Old 04-22-2012, 11:25 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
I agree that the 8.8 is not a good choice for a CJ, But a good budget axle for a YJ over the D35 joke.
It usually ends up around $1,000 including the $300- $400 cost of the 8.8, But does not include a new driveshaft if being replaced.
For that, You can buy a 1986 CJ D44 and it's a 100% direct bolt in swap.
Also, The Scout D44 is a great swap, And only needs a set of new perches.
Another option is buying a custom Currie 9" housing for $229 and scouring the junkyards for the center section.
Axles can go new or used and resplined.
Or if you can find a D60-2, But them are getting pretty scarce.
The 8.8 is a C-clip, But if it encounters a failure, The calipers will hold the axle in place to limp it out.
LT1CJ7 is offline
post #30 of 47 Old 04-22-2012, 11:37 AM
papa355
1977 CJ7
It usually ends up around $1,000For that, You can buy a 1986 CJ D44 and it's a 100% direct bolt in swap.
that's my point right there.
around here $1000 bucks will buy you an old 3/4 chevy truck with d60s and tons of other parts, then you can scrap the rest of the truck and get half your money back. Of course if full widths are not your thing (which I'd rather full width) then you have to narrow the d 60's. Just saying If I'm gonna hash out $1000; I want more to show for it than just an axle out of an exploder............
So..... your first statement holds true, 8.8 not good choice. Better options out there
papa355 is offline
8.9 , axle , cj , ford , rear axle
Disk Brakes on Ford 9" rear axle ? Bud Jeep CJ Forum 11 10-19-2010 05:29 AM
Ford 9-inch rear axle strength I6CJ7 Jeep CJ Forum 6 05-11-2010 06:21 AM
Ford 3/4 ton Axle Swap R0J Jeep CJ Forum 4 04-06-2009 01:50 PM
Ford 9 inch Rear axle jeepthing360 Jeep CJ Forum 4 10-12-2006 08:28 PM
80 Cj what front axle to match ford 9" rear? silver_2000_TJ Jeep CJ Forum 3 03-31-2005 05:42 PM
