Ford 8.8 Rear Axle - JeepForum.com
post #1 of 47 Old 04-20-2012, 07:06 PM Thread Starter
thartleystj
Ford 8.8 Rear Axle
I recently acquired a Ford 8.8 rear axle that I will be using on either a late model CJ5 or a early CJ7. My question is this: can anyone provide me with a list of what needs to be done to this axle to make it compatible with these Jeep? Thanks in advance.
1999 Jeep Wrangler TJ
4" Lift Kit, 20" XD Rockstars w/32" Nitto Terra Grapplers
thartleystj is offline
post #2 of 47 Old 04-20-2012, 07:43 PM Thread Starter
thartleystj
Any one know about these???
post #3 of 47 Old 04-20-2012, 08:09 PM
bootlegpass
I've got one under my XJ, and have another one getting ready to be put under a CJ7. They are quite a bit wider than a CJ axle. I think like 59 1/2 inches to like 54 or 56 - can't exactly remember CJ axle width. I bought an install kit from Ruff Stuff Specialties- it has everything needed (perches, plates, u-bolts, shock mounts). You will have to relocate the perches, so welding is a must. Also an adapter flange is needed to fit drive shaft. I'm sure I'm leaving out some miscellaneous stuff but that's the gist of it. Overall, it's not a bolt in deal, but not too terribly bad either. Good luck
bootlegpass is offline
post #4 of 47 Old 04-20-2012, 08:13 PM Thread Starter
thartleystj
Can you give me a link to the install kit from Ruff Stuff? Thanks for the help
post #5 of 47 Old 04-20-2012, 08:17 PM
LibertyJeeper
http://www.ruffstuffspecialties.com/...g/88SS-31.html
Originally Posted by walkerhoundvm View Post
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
Looking for axles 4.10's or higher
LibertyJeeper is offline
post #6 of 47 Old 04-20-2012, 08:24 PM
bootlegpass
post #7 of 47 Old 04-20-2012, 10:01 PM Thread Starter
thartleystj
Did you have to buy any of the add on or was the kit all you needed? Also how do you determine if it is 31 or 27 spline?
post #8 of 47 Old 04-20-2012, 10:03 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
What model Ford is the 8.8 from?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 47 Old 04-20-2012, 10:05 PM Thread Starter
thartleystj
Max
It came out of a 2000 Ford Explorer
post #10 of 47 Old 04-20-2012, 10:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The '95-'01 Ford Explorer 8.8 is 31 spline & has a track width of about 58" or so. It has a 5 on 4.5" wheel bolt pattern & disc brakes. If the door VIN sticker on the donor Explorer has an axle code that is a letter & a number, it has Ford's limited slip. If the code is a 2 digit number, it is an open differential. Example, a D2 axle code is a limited slip 4.10 ratio axle. A code 42 is a 4.10 open differential.
Max
Mean Max is offline
post #11 of 47 Old 04-20-2012, 10:22 PM Thread Starter
thartleystj
Max
Okay thanks! All I really knew about it was that it was an open differential with 3.73 gears. But its good to know that I need parts for a 31 spline. But since you seem pretty knowledgeable do you happen to know or can you tell me how to determine the spline number of a Dana 30 wide track from axle from an 85 CJ7? Thanks again!
post #12 of 47 Old 04-20-2012, 10:26 PM Thread Starter
thartleystj
Also are you sure that its a 31 spline because the only ring and pinions that I can find are either 28 spline or 30 spline...I can't find any 31 spline ring and pinions...
post #13 of 47 Old 04-21-2012, 01:37 AM
levergun
1979 CJ5
Ring and pinion spline is totally different than axle spline. Axle spline is the splines on the axle shaft that mate with the spider gears. Pinion spline is the number of splines on the pinion shaft that mate with the driveshaft flange.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #14 of 47 Old 04-21-2012, 05:11 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, all Explorer 8.8 axles are 31 spline.
Exactly.
Your Dana 30 should be 27 spline.
Max
Mean Max is offline
post #15 of 47 Old 04-21-2012, 06:20 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
The '95-'01 Ford Explorer 8.8 has a track width of about 58" or so.
The Explorer 8.8 is 60.5" wide.
The narrow track AMC 20 is 50.5" wide.
That's a hefty 10" difference.
What's your plan for the rear driveshaft & C-clip eliminator ?
LT1CJ7 is offline
8.9 , axle , cj , ford , rear axle
Disk Brakes on Ford 9" rear axle ? Bud Jeep CJ Forum 11 10-19-2010 05:29 AM
Ford 9-inch rear axle strength I6CJ7 Jeep CJ Forum 6 05-11-2010 06:21 AM
Ford 3/4 ton Axle Swap R0J Jeep CJ Forum 4 04-06-2009 01:50 PM
Ford 9 inch Rear axle jeepthing360 Jeep CJ Forum 4 10-12-2006 08:28 PM
80 Cj what front axle to match ford 9" rear? silver_2000_TJ Jeep CJ Forum 3 03-31-2005 05:42 PM
