ford 8.8 in my 83 cj7 - JeepForum.com
post #1 of 3 Old 05-29-2004, 05:20 PM Thread Starter
Big-L
I would like to swap my amc 20 out of my 83 cj7 for a ford 8.8. has anyone one done this. I see alot on the web about putting the 8.8 in th yj/tj but not the cj. why is this? thanks Big-L
Big-L is offline
post #2 of 3 Old 05-30-2004, 08:17 AM
rustyCJ
cjs use 5x5.5 wheel bolt pattern
yj/tjs use 5x4.5 wheel bolt pattern
ford 8.8 uses a 5x4.5 wheel bolt pattern
ford 8.8 axle flanges dont have enough material to be redrilled to 5x5.5 wheel bolt pattern
the cost needed to swap an 8.8 under a cj out weighs the gain.
the reason the axle is so popular with yj/tj owners is becuase its a pretty low buck upgrade over the crappy D35 because all that is needed is to bolt the axle under the jeep and the swap is done. this wouldnt be the case with a swap into a cj. due to the 8.8s width it would either need narrowed or youd have to swap out the D30 front for something wider.
these are just a couple reasons why the 8.8 isnt a good cj swap and there are others.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #3 of 3 Old 05-30-2004, 08:23 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would try to locate a Scout rear Dana 44 and use that. Same bolt pattern, and I believe the almost the same width as the Widetrac AMC 20 in your CJ. Just have to move the spring perches in a bit.
BESRK is offline
2.3T Ford CJ7 Cutlass327 Jeep CJ Forum 11 05-26-2013 10:16 PM
SBC or Ford v8? redbird2289 Jeep CJ Forum 20 11-29-2009 04:11 AM
CJ vs FORD Decscorpion Jeep CJ Forum 17 07-02-2009 09:32 PM
Value of Ford T18 supraman1990 Jeep CJ Forum 2 06-14-2008 05:57 PM
