Ford 302 vs 351 - JeepForum.com
post #1 of 19 Old 08-31-2011, 08:52 AM Thread Starter
ctappan94
1983 CJ7
Ford 302 vs 351
I have an 83 CJ7 and I was wondering what motor would better suit it. I want a lopey idle.. like the top fuel dragsters.. and want adequate torque to wheel... but then again..jeeps have to be pretty light, as I've seen that 6.0l powerstroke jeep on the dunes and it didnt fair so well.. I want reliability as well, yet not SO much power that I crack the frame... because Im told its not nearly as strong as the Yj's and well lets face it, its almost 30 years old!
ctappan94 is offline
post #2 of 19 Old 08-31-2011, 09:13 AM
BioTex
1979 CJ7
It's easier to de-tune a 351, than it is to hot rod a 302. I'd build a 351 and never look back.
Back in the day, the Cleveland was the better motor, but today I'm hearing that the windsor engines are what's going in most of the Cobras. Maybe it is just because it is too hard/expensive to get a cleveland IDK.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 19 Old 08-31-2011, 09:24 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
You won't want that lopey idle when trying to maneuver over an obstacle. Those cams are that way because they are designed for high RPM power. They have nothing to offer in the lower RPM ranges, where your Jeep would be spending most of it's time on trails.
As for 351w or 302, the 351 has more cubes, so it will have more output from the start. If you want to build something with power, go the 351w. Just remember that the bottom half externally is the same as a 302, but the top is wider, so clearance is gonna be a little tighter for the steering shaft to headers and such. The advantage is that 302 motor mounts and such should fit it in there. You will also have to find a oil pan that fits, I think the one from the cars are needed, and there weren't many 351w cars, so an aftermarket pan for a mustang swap or something may be required.
Rick
Cutlass327 is offline
post #4 of 19 Old 08-31-2011, 09:36 AM
colojeepguy
1970 CJ5
Ford cars used a front sump oil pan. 4x4 trucks used a rear sump oil pan. You also need the pick up tube that goes with the pan.
colojeepguy is offline
post #5 of 19 Old 08-31-2011, 09:55 AM
ideal_trucks
1978 CJ5
I think the 351W is only about an inch wider up top. Not much at all. From looking you really can't even tell the two engines apart.
ideal_trucks is offline
post #6 of 19 Old 08-31-2011, 11:27 AM
foggybottombob
My neighbor has a 302 in a highly modified Bronco. The engine is pitiful. If you have to have a Ford engine go with the 351.
foggybottombob is offline
post #7 of 19 Old 08-31-2011, 11:55 AM
Coiz
1979 CJ7
Curious as to what makes it pitiful?
My friend had a hopped up 289 in his Bronco that just plain ripped. He swapped that out for a FI 302 and it still gets around pretty good. Mine doesn't seem anemic to me either. Sure if I had 38's with 2.73's but that is hardly the engines fault. The year of the engine and the compression ratio will also make a difference.
Mike
Coiz is offline
post #8 of 19 Old 08-31-2011, 12:07 PM
ideal_trucks
1978 CJ5
A 302 can be made to be pretty beastly. It really depends on what is done to it. A stock 302 from late 80's early 90's is pretty pitiful though. A 351 isn't much better, but is not bad. Cousin has a 351 bronco with 33's and T18. 3.73 gears. My 258 jeep with t18 and 3.55 will run with it.
Put a little head work and you could have a strong engine. Or get an older, pre '70 351w and you've really got something there.
post #9 of 19 Old 08-31-2011, 12:21 PM
Jim1611
Jim1611's Avatar
Allot depends on what you plan to use your Jeep for as to which engine would be better. If you want a dependable daily driver that isn't going to break you on fule then the 302 can't be beat. It's also ligther than the 258 you now have and the 351 too. If you rub the 302 you need to make a decision, now. The 302 is well noted for being a quick revving engine. The ones Ford used in the later Mustangs that are fuel injected are easily modified to make 300 hp. A stock 302 has less than desirable heads. That can easily be changed.
The 351, in my opinion, is somewhat of a neglected engine. It's longer stroke makes better torque than the 302, which is good for slow speed crawling. It is heavier than the 302 though. Also as noted a bit bigger.
Either engine would make a good swap for you but you're going to have to decide what you want to use it for and build accordingly. As Cutlass327 said the rough idle cam won't be much good.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #10 of 19 Old 08-31-2011, 12:40 PM
1Aauto
Vendor
1Aauto's Avatar
The heads that came on the Mustangs were choked. If you do a 302 get a set of aftermarket heads and you'll uncork tons of power.
SHOP HERE FOR AWESOME
1Aauto is offline
post #11 of 19 Old 08-31-2011, 12:52 PM
ideal_trucks
1978 CJ5
You can put 351w heads on a 302 also and get alot more power, or the gt40 heads off the explorers.
post #12 of 19 Old 08-31-2011, 01:28 PM
CSP
That depends highly on what Mustang you're talking about. I had a '93 Cobra which had the GT40 heads, which are far from restrictive.
CSP is offline
post #13 of 19 Old 08-31-2011, 01:34 PM
PeeWeeHerman
if you can find a 5.0l explorer motor its a great cheap motor get a nice low end torque cam, valve springs and some rockers and you have a 260/315 hp/tq engine. If you ever want more power/break there are a ton of cheap parts for the 302 compared to the 351. Intakes are abundant for the 302.
as for a hopped up 302 in the one post being pitiful, im curious as to the specs.
Don't do business with Tuff Designs, worst retailer ever.
PeeWeeHerman is offline
post #14 of 19 Old 08-31-2011, 01:47 PM
1Aauto
Vendor
1Aauto's Avatar
I put the Holley Systemmax intake on my Mustang and that really woke it up. That's for a fuelie set up though. If you search Craigslist. Look for Mustang parts if you decide to go with a 302. You could probably find a set of heads and a intake or carb for a reasonable price.
1Aauto is offline
post #15 of 19 Old 08-31-2011, 01:58 PM
Jim1611
Jim1611's Avatar
If money wasn't an object I'd say a stroked 5.0 would be the best of both worlds.
My build thread
Ford FE 352 V8 into a CJ BlueOvalBud Jeep CJ Forum 13 12-21-2009 02:27 AM
Ford 360 or AMC 360???? Bobby9821 Jeep CJ Forum 19 12-18-2009 10:44 PM
Ford 8.8 in a CJ? Roadymi Jeep CJ Forum 4 11-08-2009 06:58 AM
Ford 302 in CJ - what mpg you get? Cutlass327 Jeep CJ Forum 8 11-03-2009 05:57 PM
Ford T18 into a CJ? CjinPA Jeep CJ Forum 3 02-07-2007 02:12 AM
