Fog light wiring - JeepForum.com
post #1 of 8 Old 12-28-2006, 07:46 PM Thread Starter
Bubba Ray
Fog light wiring
I am installing new Hella 500 fog lights and don't understand why I have to tie into the headlights. I want to be able to use the lights Independently of the headlights. The instructions show tying into the high beam headlight wiring. Can I skip this step? Any help would be appreciated.
Bubba Ray is offline
post #2 of 8 Old 12-28-2006, 07:51 PM
Aphelion79
Aphelion79's Avatar
Yeah, they just want them to only be able to be turned on, if you have your high beams on... you don't HAVE to do that...
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
post #3 of 8 Old 12-29-2006, 12:10 AM
Wolf359
WOLF359
Wolf359's Avatar
Here's a simple wiring diagram to hook up the lights to a manual switch.
Wolf359 is offline
post #4 of 8 Old 12-29-2006, 07:31 AM Thread Starter
Bubba Ray
I went to Hellas web site and found different instructions. They say that for off road use only tap into parking lamp wire to operate lamps independently from high and low beams. Parking lamps must be on to operate. I can live with this setup. Thanks for the tips. My CJ7 would not run without this website.
post #5 of 8 Old 12-29-2006, 09:23 AM
CJ Chet
Notice that they said "Off road only"! Some states require fog lights to be wired to operate with low beam headlights only. Due to the way they are focused and project light, I can't think of any situation where you would want to operate only fog lights and nothing else. They are designed to compliment low beams by shining low, close and wide.
Also, you really should run their power through a relay. If you put them through the parking lights they will always be on with ANY lights. If they are high power bulbs I doubt if those parking light wires will supply enough current, unless you use them to just operate the relay (with an independant switch).
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #6 of 8 Old 12-29-2006, 09:49 AM
CJ7Rubicon
CJ7Rubicon's Avatar
I hooked the relay trigger wire to a "key on only hot fuse".Then put a toggle switch in line with that to the relay.Of course the other side of the relay is hooked to battery pos. and fog lights.That way the relay is only pulling minimum power thru the toggle,but full power directly off battery.
85 CJ7,Clifford equipped 258,TBI,RE4.5,35" Claws,Aussie lockers,8.8 rear.
Blue Jeep Club Member #134
CJ7Rubicon is offline
post #7 of 8 Old 12-29-2006, 10:21 AM
CJ Chet
That's the way to do it! I also ran my DUI distributor that way, with 10 gauge wire, so I'd get maximum fire!
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #8 of 8 Old 12-30-2006, 07:47 AM Thread Starter
Bubba Ray
The Hella kit came with a relay. The switch needs a small current to work the relay. The install was not bad and the lights work great. Went offroad last night and was pleased with added light. I may convert the headlights to a relay as well.
OEM fog light wiring and diagram idl Jeep CJ Forum 17 12-22-2013 08:28 AM
Wiring in an "OH-**** light.... starfire340 Jeep CJ Forum 13 01-23-2008 10:54 AM
Trailer light wiring for CJ SuB8HaVeN Jeep CJ Forum 1 08-04-2007 04:08 PM
Please help with LED light wiring... fromme Jeep CJ Forum 8 04-06-2006 10:08 PM
Tail-light wiring jeepsarecool Jeep CJ Forum 8 04-02-2006 06:46 PM
