Flywheel / Starter noise ?? - JeepForum.com
post #1 of 4 Old 01-13-2002, 09:52 AM Thread Starter
Guy Hollister
Cool Flywheel / Starter noise ??
Annoying spinning grinding sound...
Only on start... and lasts for about 3-4 seconds - I believe its the flywheel contacting badly with the starter... once it jammed into the starter and because its auto it was a PAIN in the BUTT... I had to get a tow off the farm to get the starter off and free it from the flywheel... its also exactly below my sheared dipstick pipe which means I got COVERED in oil head to toe. Nice.
When I removed the starter I bothered to inspect the flywheel and noticed quite a few teeth were 1/2 chipped off... on the outside edge - contacting with starter edge.
It hasn't been making that noise for a long time - but recently just started making it again.
Help !?
Cheers
Guy
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
post #2 of 4 Old 01-13-2002, 11:40 AM
Darko
Post
How old is your starter? Maybe the starter gear which engages the gear isn't disengagin properly.
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #3 of 4 Old 01-14-2002, 02:03 AM Thread Starter
Guy Hollister
Cool
No idea - may be the original... 1984....
G
1984 RHD CJ7
1979 LHD CJ5
post #4 of 4 Old 01-18-2002, 07:56 AM
Rip
Post
It a quick fix, well kinda of. you can have your ring gear flipped on the flywheel and get some more use out of it. I did that cause I had the same problem. and no money to buy a new one (flywheel) One solution is to get some never cease(sp) grease and apply a little on the starter shaft where the gear slides on the shaft (Bendix) It helped mine.sometimes it gets dirty and doesn't quite enguage all the way. ....Rip
Rip is offline
Starter not engaging flywheel! trueprimitive Jeep CJ Forum 7 08-05-2009 10:05 PM
new starter, new flywheel, both chewed up yttaf Jeep CJ Forum 6 10-09-2008 05:45 PM
Starter/flywheel shim? motojoe Jeep CJ Forum 5 02-28-2008 09:01 AM
CJ 5 Starter Flywheel Mismatch rculp Jeep CJ Forum 3 01-28-2007 08:16 PM
Starter not contacting flywheel collinpyle Jeep CJ Forum 13 11-24-2006 11:33 AM
