fly wheel problem - JeepForum.com
post #1 of 3 Old 12-29-2005, 01:54 AM Thread Starter
outdoordad@comc
fly wheel problem
have an 86 cj7 with an 86 bellhousing and an 87b wrangler motor. Found out what my motor noise was .... the starter is engaged from bolt up???? WTF ? anyone else have this problem? I have an 86 flywheel and will check thei diff out tomorrow but on the 87 the flywheel teeth are right next to the inspection plate or dust shield? any words of wisdom here are GREATLY APPRECIATED.... did the machine shop give me the wrong fly wheel? the clearance from the bottom id edge of the flywheel to bellhousing is about 1/8th of an inch.... sound right? this is the 87 flywheel..... well until the later eve help me out friends
happy hew year
Sean
outdoordad@comc is offline
post #2 of 3 Old 12-30-2005, 11:43 AM
Rockram1
I wouldn't think they would be different. I wonder if they didn't put it on backwards or if thats possible.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
post #3 of 3 Old 12-30-2005, 01:00 PM Thread Starter
outdoordad@comc
good thought but i was the one that put it on originally, and after taking the one from my old motor out there its completely different in style.... i had recieved the wrong flywheel from the shop. kinda pisses me off but at least this will get done now.
1978 cj7 problem going int 4 wheel drive extremecj7 Jeep CJ Forum 7 12-24-2008 11:14 PM
Tilt wheel/brake light problem ThrlSkr Jeep CJ Forum 2 10-05-2007 05:05 PM
Jeep Cj7 4 wheel drive light problem funinfuneral Jeep CJ Forum 7 07-20-2007 02:30 PM
wheel balance problem wjr Jeep CJ Forum 9 02-04-2007 10:18 PM
Rear Wheel Bearing Problem... Swedish_K Jeep CJ Forum 6 06-21-2005 04:55 PM
