Fluids - JeepForum.com
post #1 of 5 Old 11-04-2013, 06:46 AM Thread Starter
LeePrather
1978 CJ5
Fluids
Is there any issue running royal purple 75w-90 in tcase, tranny and diffs?
LeePrather is offline
post #2 of 5 Old 11-04-2013, 07:11 AM
WindKnot
1977 CJ7
The FSM calls for 80wt GL-4 in the transmission & transfer case.
Differentials are 80-90wt GL-5 for open, & Trac-Loks want 80-90wt GL-5 LIMITED SLIP.
Personally, I would NOT use a GL-5 oil where GL-5 oil is called out. GL-5 has a higher sulphur content which will attack brass components. A differential has no brass parts, so the GL-5 is useful.
The oil weight is probably fine. Worry about the additives.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 5 Old 11-04-2013, 07:41 AM Thread Starter
LeePrather
1978 CJ5
Originally Posted by WindKnot
The FSM calls for 80wt GL-4 in the transmission & transfer case. Differentials are 80-90wt GL-5 for open, & Trac-Loks want 80-90wt GL-5 LIMITED SLIP. Personally, I would NOT use a GL-5 oil where GL-5 oil is called out. GL-5 has a higher sulphur content which will attack brass components. A differential has no brass parts, so the GL-5 is useful. The oil weight is probably fine. Worry about the additives.
I saw most people recomending the 75w-80, but I couldn't find any...it's just crazy how different this stuff can be when it looks so similar...
post #4 of 5 Old 11-04-2013, 07:43 AM
CSP
Royal Purple is a synthetic and synthetic GL5s don't have the sulphur that eats yellow metals. It should be fine in all of the gearboxes.
CSP is offline
post #5 of 5 Old 11-04-2013, 01:25 PM Thread Starter
LeePrather
1978 CJ5
Thanks...it ain't cheap and I wanted to cover them all
