-   -   Fluids (http://www.jeepforum.com/forum/f8/fluids-1755946/)
LeePrather 11-04-2013 06:46 AM
Fluids
Is there any issue running royal purple 75w-90 in tcase, tranny and diffs?
WindKnot 11-04-2013 07:11 AM
The FSM calls for 80wt GL-4 in the transmission & transfer case.
Differentials are 80-90wt GL-5 for open, & Trac-Loks want 80-90wt GL-5 LIMITED SLIP.
Personally, I would NOT use a GL-5 oil where GL-5 oil is called out. GL-5 has a higher sulphur content which will attack brass components. A differential has no brass parts, so the GL-5 is useful.
The oil weight is probably fine. Worry about the additives.
LeePrather 11-04-2013 07:41 AM
Originally Posted by WindKnot
The FSM calls for 80wt GL-4 in the transmission & transfer case. Differentials are 80-90wt GL-5 for open, & Trac-Loks want 80-90wt GL-5 LIMITED SLIP. Personally, I would NOT use a GL-5 oil where GL-5 oil is called out. GL-5 has a higher sulphur content which will attack brass components. A differential has no brass parts, so the GL-5 is useful. The oil weight is probably fine. Worry about the additives.
I saw most people recomending the 75w-80, but I couldn't find any...it's just crazy how different this stuff can be when it looks so similar...
CSP 11-04-2013 07:43 AM
Royal Purple is a synthetic and synthetic GL5s don't have the sulphur that eats yellow metals. It should be fine in all of the gearboxes.
LeePrather 11-04-2013 01:25 PM
Thanks...it ain't cheap and I wanted to cover them all
The time now is 10:51 PM.
