Fluid for a T-5 - JeepForum.com
post #1 of 4 Old 02-18-2002, 02:41 PM Thread Starter
Petey
Post Fluid for a T-5
I ‘ve been working on my transmission, a T-5, and I am about ready to fill it back up with fluid. However, I have been unable to find out what to put back in it. My Haynes manual gives me a Jeep part number and this number means nothing to the local Jeep dealer and the Chilton manual says to use Dexron II. The fluid that came out of the tranny looks like a gear oil (90W).
Anybody know?
86 CJ7 w/ a 258.
Petey is offline
post #2 of 4 Old 02-18-2002, 02:54 PM
West
Post
use the dexron II
West is offline
post #3 of 4 Old 02-20-2002, 04:29 PM
KeenCJ7
Lightbulb
I had the same problem when I had a T5 and I read some where that dextron II would work but was not reccomended. After a couple trips to the Jeep dealer and a couple different parts people later, A guy understood my problem and actually ordered me some of the oil. It is a real light weight oil, but I cant remember if the part# was still the same. The guy had to pull out an old manual to find the stuff. What ever you do don't put 90w back in, it will screw up yo syncros
84 CJ7 with tons of mods
RigRater Score:
704RRv1.0 with a BOA of 23.07 -- <a href="
target="_blank">http://www.rigrater.com</a>
KeenCJ7 is offline
post #4 of 4 Old 02-20-2002, 04:54 PM
jeepster18_88
Post
The T5 in my '85 CJ7 calls for GL-4 80w90. The dana 300 transfer case calls for GL-5 85w90. I couldn't find either one anywhere so I asked a mechanic that I know that works mainly on Jeeps. He also owns 3 of them. He said to use the GL-5 80w90 for the both the T5 and the Dana 300. I replaced the fluid in my tranny and now it shifts so much smoother. The dexron will screw up your tranny but not the 80w90. That's the stuff that the factory had in it. As for the GL rating, 5 is just better quality than the 4. Hope it helps.
Josh
jeepster18_88 is offline
Brake Fluid & ATF Fluid Questions avking Jeep CJ Forum 1 04-03-2009 11:55 AM
T-18 Fluid Andy5150 Jeep CJ Forum 7 06-18-2008 08:09 AM
What fluid? Mud4U Jeep CJ Forum 8 04-05-2006 10:25 AM
Which fluid? Mud4U Jeep CJ Forum 7 12-12-2005 04:53 PM
D-300 fluid level check and what kind of fluid? NJCJ7 Jeep CJ Forum 1 03-16-2004 08:02 AM
