Fluid Levels - Page 2 - JeepForum.com
post #16 of 21 Old 08-25-2013, 09:27 PM Thread Starter
cjohnson2209
1980 CJ7
Also, I am pretty sure it has a Dana 300 t-case based on the pattern: 4low in front and N, 2high, 4high in the back. Does that make sense? Does that make a difference in fluid type or amount?
cjohnson2209 is offline
post #17 of 21 Old 08-25-2013, 10:29 PM
cardiffclimber
1981 CJ7
I initially went with 90W gear oil when I first swapped a T5 in my '81 because that's what I always thought went in a manual transmission. It worked okay, but shifting was not the best.
When I went to change the oil, I read in a manual for an '84 that came with a T5 that the recommended fluid is ATF.
I tried it, and shifting improved considerably.
"Rule #9.1: Never go anywhere without a jeep."
cardiffclimber is offline
post #18 of 21 Old 08-26-2013, 09:15 AM
LumpyGrits
Originally Posted by cardiffclimber View Post
If it is a T4, you want to use ATF.
NOPE-------That's what AMC did against BW's recommendation. They replaced allot of trannys.
Use the 75W-90 syn. It works.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #19 of 21 Old 08-26-2013, 09:17 AM
LumpyGrits
Use std gear oil 85W-90.
LG
post #20 of 21 Old 08-26-2013, 12:16 PM
wkp
1980 CJ7
After much research ( on this site and others ) , I ended up using NAPA GL4 (part number # SL24239 ) in my SR4 which is basically the same as the T4. Its been in for several years with no problems. Supposedly safe for the brass/bronze parts.
wkp is offline
post #21 of 21 Old 08-27-2013, 08:52 PM
cardiffclimber
1981 CJ7
LG
Um... I wish I would have known that. Thanks for the info, I'll put that on the top of my list of things to do.
cj7 , fluid capacity , t-case , tranny mount , transmission fluid level
