Floor pan drain plugs - JeepForum.com
post #1 of 10 Old 10-08-2013, 07:39 PM Thread Starter
drespecki
1983 CJ7
Did my interior with monstaliner and now need to plug all the drain holes... What have people used with good luck, the hard rubber ones by Crown or the ebay plastic ones? Or perhaps something else? I checked the diameter and they all seem to be about 15/16 across...
It only hurts while you're breathing..
drespecki is offline
post #2 of 10 Old 10-08-2013, 07:50 PM
mvigo
mvigo's Avatar
I went to the hardware store and bought them there...inexpensive and they work like a champ...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #3 of 10 Old 10-08-2013, 07:50 PM
PROJECT 23
Check Lowes or Home Depot as well. You might find something on the cheap and just as good.
Just a thought.....
PROJECT 23 is offline
post #4 of 10 Old 10-08-2013, 07:59 PM
cj7ole
Floor plugs? Don't need no stinkin' floor plugs...
'84 CJ7, '07 5.3 LMG Chevy, D300, 4L60e, 33's, 4.10, rear Detroit Locker, FG Tub, HOK Tangelo Pearl
Build: http://www.jeepforum.com/forum/f22/ole-jays-cj7-5-3-chevy-swap-1287392/
cj7ole is offline
post #5 of 10 Old 10-08-2013, 08:07 PM
dg6772
x2. plugs? Aren't those in the engine?
I've seen whole kits on Ebay for under 10 bucks
Dave in Muskegon
dg6772 is offline
post #6 of 10 Old 10-09-2013, 06:40 AM
gmakra
You can get 3/4 inch plastic knock out plugs (in the electrical aisle) from any hardware store for cheap and that what I use.
gmakra is offline
post #7 of 10 Old 10-09-2013, 07:14 AM
capt205
1983 CJ7
My plug holes are covered by rubber floor mats...not a plug in sight.
This is my 5th CJ...never had plugs in any of them.
capt205 is offline
post #8 of 10 Old 10-09-2013, 07:52 AM
WindKnot
1977 CJ7
As mentioned, you can find them in the fastener section of a hardware store. Before you go, measure! the holes changed size from year to year.
I use them as I ford streams frequently. I'm also remember to remove them when necessary. Don't be afraid to pull the plugs if you need to!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #9 of 10 Old 10-09-2013, 08:22 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Without plugs, the tires will kick dust, water, mud, gravel, even thumb-sized rocks inside, especially near the roll bar mounts and front floor pans. This not only makes a friggen mess, it contributes to the rot that is so common in these areas.
I found these nice aluminum plugs at my local hardware store. They stay in place and hold up longer than the factory plastic plugs...and they look good.
Matt
Matt1981CJ7 is offline
post #10 of 10 Old 10-12-2013, 04:38 PM
cj7ole
Fiberglass body = no rot. Rubber floor mats = no splash, rocks, dust. I have two rubber plugs in my console, haven't had them in for over 6 years.
cj7ole is offline
