Quantcast which flex plate do I need - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > which flex plate do I need
Old 06-24-2009, 08:07 PM   #1
ctm
Question is for an 84 CJ7: 84 TF999 tranny with an 88 YJ 4.2 engine and crank....I am not sure which flex plate to order, there are different part numbers between these years. 3232138 is for 80-87 (I guess used for CJ and then YJ first year 87); and then 33004359 for 88-90 YJ.
The pics look very similar, is there really any difference? they have the same diameter and tooth count
3232138 (Makco A300)
33004359 (Makco A310)
this is the Makco catalog link:
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Cod e=FLYcatalogAMC
ctm is offline   Reply With Quote
Old 06-25-2009, 04:13 AM   #2
BigTDog
I'm going through this also. I know the starter has a shorter bendix for the 88' YJ motor. It looks to me that the flex plate is closer to the block. Not sure if it's the crank or flex plate.
BigTDog is offline   Reply With Quote
Old 06-25-2009, 04:06 PM   #3
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Just a small point of information. That part was made by a company named Bendix. Its not called a "bendix" - not even in the FSM.
I forget what the real name of it is and will have to go look it up now. Last time I remember discussing this was like 10 years ago on the AMC-List.
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline   Reply With Quote
Old 06-27-2009, 12:33 PM   #4
ctm
So now I went to mock up what I have to see if the flex plate is correct for my 88 block/84 tranny combo. Everything bolts up but I am not convinced that the starter I have is correct for the original CJ flex plate. My ring gear is almost a full 1" from the block face and that puts the ring gear teeth on the far outer part of the starter throw...here's some pics, does it seem correct?? I am thinking maybe if the YJ flex plate is a bit closer to the block then it may work better than this:
Glock Forum
