#1 | |
flex fan vs. electric fan
which one would be quieter, work better, and maybe even provide more horsepower.
and what are the installation steps on both what is the most effient option?
1986 CJ7 258 Inline 6 HEI Distributor 4.0 Head Swap MC 2150 lOd Rear Tire Carrier Soon to be: 4.0 Motor All New Wiring Gauges OBA Spyder Customs Crusher Corners http://www.cardomain.com/ride/2527972/1 |
#2 |
flex fan can decrease horsepower quite a bit from what i understand. someone back me up with some facts.
#3 |
flex fan is a bad idea for offroad. an electric fan is claimed to add a decent amount of horse power. Should be around the same price as a flex fan too. My vote is for the electric.
Female owned, built & beaten. Charlee "Nancy" '99 XJ: 10" lift, 37x14" Iroks - D44 front & rear, Safari Snorkle, ETC. ETC. |
#4 |
anyone know how long and what it takes to install a electric fan?
and what width would i need a cj with 258
#6 |
I had a "Fixed" Flex Lite fan on my 4.2. It was a horsepower hog and very noisy, although it was very reliable. I changed to an electric fan (from Ford Contour-they work great) and I could really tell the difference. The engine was really alot more responsive. That Flex-a-lite from Summit is sure the way to go (a bit pricey though).
Beer is the answer - it doesn't matter what the question is! '86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift. '04 TJ Sahara. '00 TJ Sahara. |
#7 |
hey chet was it hard to hook it up on a thermosat where it turned on by itself. like do the aftermarket harnesses for that plug right up?
#8 | |
GROUND POUNDER
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#9 |
will the aftermarket one plug up to...say...a fan from a ford escort?
#10 |
Anything is possible, most likely it will you would just have to hook it to the correct wires. Think of the ford contour fan as an aftermarket fan.
1993 Grand Cherokee Limited, 5.2L Modified/Slightly Ported Kegger Air hat spacer Modified Throttle body Flowmaster muffler |
#11 |
Flex fans tend to eat radiators when driven through deep water. Use a clutch fan or electric.
Enjoy! |
#12 |
I got a thermostat setup, like Besrk talked about, from Autozone for about $19 (complete kit).
#13 | |
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes. Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA, |
#14 |
That's the one. It's set up for 190 degrees, and so far so good!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
