Flatty build ?... - JeepForum.com
post #1 of 9 Old 08-22-2006, 12:01 PM Thread Starter
Jeepfreak81
Jeepfreak81's Avatar
Flatty build ?...
ok I really have one question, but I figure I better give as much background as possible. the following is what I want to do...
I think I finally have my build plan, and the engine goes in today so its a good time to post.... I hate snags
that mixed with a
triangulated 4 link rear on Stock TJ springs,
SOA front
231 V6
T-14
D18
Power brakes
Hanging pedals
slight stretch (very slight)
pizza cutters
winch
possible PTO (if I can find one)
Stock Axles 5.38 gears
Saggy swap (manual steering temporarily)
Eventually a set of Autometers
The jeep will have a military arctic hardtop off a M38 as well.
I had a question here and edited it out... my second choice of a powerplant was not a good one... and I went back with my first choice
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #2 of 9 Old 08-22-2006, 01:10 PM
mxg342
mxg342's Avatar
Why do all of this work and stay with the old axles. Find a front 30 from a narrow track CJ with disc brakes and a rear d44 from a 72-75 CJ5. Then mate the dana 300 to the t4 and go from there.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #3 of 9 Old 08-22-2006, 01:14 PM Thread Starter
Jeepfreak81
Because I want to be narrow/short and different. I want it to look somewhat stock from 50' away, then the person walks up and is like holy sh%t! Eventually i will stuff a 2.5 FI out of a YJ/TJ or the newer OHC Jeep 4 cyl in it.
I have one trail rig I am happy with, now I want to experiment.
post #4 of 9 Old 08-22-2006, 02:29 PM
earlycj5
Kinda thinking outloud here.
Can you use a bellhousing from a S10 that would bolt to the the engine and to the adaptor for a Buick V6 to bolt up to the T14/D18?
regards,
Sparky
earlycj5 is offline
post #5 of 9 Old 08-22-2006, 02:41 PM Thread Starter
Jeepfreak81
I think the current bellhousing I have will bolt to the T14 by drilling 2 holes... If it will I will be set *I think* (it basically is the s-10 housing) my T14 has the V6 adapter on it already... so I will find out.
The only bell/clutch issues I am seeing is if I have the rare T4 with the higher spline count on the input, and I think if I buy a new clutch that will not matter anyway.
My first problem was I was hoping to use the T4 instead of the T14 just for the sake of having more gears to choose from. Both are a 1:1 final drive.
This is going to be for cruising round town and maybe to play with and not worry as much about, it will easily fit on my 4 place snowmobile trailer (very heavy duty home made one), or flat tow behind my YJ or truck if needed too. I eventually will throw a restoration tub on the chassis if I like the setup
I am just trying to improve the original design without totally ruining the classic look. Like my stretch will be 3-4" max as I do NOT want a comp cut rig.
post #6 of 9 Old 08-22-2006, 02:46 PM
earlycj5
Yeah, I know they're both 1:1 final drive. I was just trying to figure the simplest way to keep the D18 and offset rear axle. Like I said, thinking, err, typing out loud.
I think a later FI 2.5L would be very cool in a flattie, esp. mated to an SM420, in a stockish configuration. Trail sleeper for sure. Maybe a 2" lift, some 34x9.5 Swampers, lockers F/R.
Oh, sorry. Back to your Flattie. I think it sounds like a fun project.
regards,
Sparky
earlycj5 is offline
post #7 of 9 Old 08-22-2006, 02:55 PM Thread Starter
Jeepfreak81
Yeah the offset rear has really limited me... So I keep the D18 as my t-case, I don't know of a whole lot of other options. -- But I promised myself I would not swap axles and I am trying not to swap rims either... I like the look of Animal, (even though its not a flattie)
The thing is I think the TJ springs may get me up too high where I HAVE to swap rims... But i want pizza cutters for sure...
It will at least have a rear locker (lincoln locker most likely)
post #8 of 9 Old 08-22-2006, 03:01 PM
earlycj5
Animal looks pretty stock until you get in. Then you realize how tall it is.
I guess Animal has influenced my ideal Jeep.
Notice my tires are relatively tall and skinny too.
Heck, w3srl's yellow flattie is a very capable rig, 31x10.5 Swampers IIRC. That with the scenario I described minus the lift. Tasty.
regards,
Sparky
earlycj5 is offline
post #9 of 9 Old 08-23-2006, 06:18 AM Thread Starter
Jeepfreak81
Ran into snags... My T14 is the V6 T14 only. Due to input length I can not use it without an adapter as well. it also has a rare (made 2 years only) 10 spline output to mate it to the D18
The T4 I have is an rare 14 spline input version found only in some 1986 CJ's,
The motor would fit nicely if I put on a small body lift.
how i end up with the 'rare' version is beyond me...
best mastercylinder for 48 flatty vswv8 Jeep CJ Forum 2 06-24-2008 07:02 PM
Cheep and easy snorkle for my Flatty ronprice Jeep CJ Forum 8 08-27-2007 10:28 AM
project flatty...follow along Mr.Crowley Jeep CJ Forum 8 05-21-2007 09:07 PM
??'s about a flatty purchase Mr.Crowley Jeep CJ Forum 8 01-22-2007 09:19 PM
