Flat towing / tow bar /CJ-7 with Dana 300 Transfer case - Page 2 - JeepForum.com
post #16 of 27 Old 09-11-2013, 04:40 PM
CSP
The way I look at it is that it's a matter of when, not if.
I've done a lot of things that I've gotten away with, knowing that they could go bad. That doesn't mean I made the right choice just because they didn't go bad when attempted.
CSP is offline
post #17 of 27 Old 09-12-2013, 08:58 PM
cj7ole
In the last 6 weeks I have towed the CJ 5500 miles around the west behind the RV and another 3k before I get home. Before that probably more than 10k in over 20 years. Disconnect the rear DS, unlock the front hubs and it makes no difference where you leave the tranny and TC levers. But to be safe I put the TC in neutral, reach under and make sure the front DS turns freely, then there is no worry. Just make sure your front and rear wheel/axle bearings are in good shape. Last thing you want is to look in the rearview mirror/camera and see a flaming pile of Jeep behind you. I tow with a 10 ton motor home and use an auxiliary brake (Brake Buddy). Tow behind a pickup or SUV and you can easily have the tail wagging the dog. I know, I flat towed it 15 years behind Safari van with no auxiliary brake. Many states require aux brakes. And I have a checklist on my phone I go through every time I hook it up.
I used to just disconnect the rear DS and hang it on the muffler, but now I remove it, wrap the u-joints in 2 layers of electrical tape and stuff it in a piece of 4” PVC pipe with a cap on one end and a screw plug on the other and lay it on the rear floor. And when I replace it I torque the strap bolts to 16 ft-lbs. Takes 10 minutes in or out.
And I am still using the original a-frame tow bar purchased 20 years ago. Break away cable is not shown in the pic. I have no idea why in the world you would leave the front hubs locked, leaving everything to spin when the purpose of the hubs is to unlock everything.
'84 CJ7, '07 5.3 LMG Chevy, D300, 4L60e, 33's, 4.10, rear Detroit Locker, FG Tub, HOK Tangelo Pearl
Build: http://www.jeepforum.com/forum/f22/ole-jays-cj7-5-3-chevy-swap-1287392/
cj7ole is offline
post #18 of 27 Old 09-12-2013, 11:03 PM
LumpyGrits
There is no requirement for a secondary braking system when towing a motor vehicle. A trailer yes, anything over 1500 lbs GVWR.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #19 of 27 Old 09-13-2013, 08:46 AM
DougE
1983 CJ7
Small car hauler trailer solves all problems and concerns, plus has brakes. Hitch on Jeep spots unloaded trailer where you want it, easily.
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
post #20 of 27 Old 09-13-2013, 10:41 AM
LumpyGrits
Trailer=$$$ plus storage concerns.
I used a Featherlite for years. Sold it and just flat tow now.
LG
post #21 of 27 Old 09-15-2013, 05:02 PM Thread Starter
GlennLever
GlennLever's Avatar
After considering all the options, I will be buying a 16 enclosed trailer to put the Jeep into for towing and use the same trailer for winter storage of the Jeep.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #22 of 27 Old 09-15-2013, 06:30 PM
LumpyGrits
It's your money, to do as you want.
Think you mind was set, BEFORE you posted.............
LG
post #23 of 27 Old 09-15-2013, 08:44 PM Thread Starter
GlennLever
GlennLever's Avatar
LG
I had no idea what I was going to do before I posted, thank you very much.
Glenn R. Lever
My Web Site
post #24 of 27 Old 09-16-2013, 05:10 PM
rcsutton
2010 JK Wrangler
$3500.00 later
I flat towed my Jeep for years everything in neutral. 350 miles from my house this spring somehow the Jeep went into gear not sure what happened, but from the cracked bell housing to the yoke of the rear end was grenaded. In Milwaukee I had to replace the bell housing, transfer case, tranny OK?, the driveshaft and yoke. Believe me take the 5 minutes or so and disconnect the driveshaft. It's an expensive lesson. And I did make sure everything was in neutral.
2010 2 door JK Red Rubicon.
rcsutton is offline
post #25 of 27 Old 09-17-2013, 07:20 AM
DougE
1983 CJ7
Browsing this plus RV forums I have found many incidents of unintended damage, as above, caused to the toad by forgetfulness, mistakes, etc. I have towed a Sidekick many, many miles without problems but have forgotten to put in one pin when distracted by a park employee complaining about me doing the tow bar hookup on the grass. Thankfully no damage, having been alerted by another driver. Have blown a tire on the toad and damaged body. Have tried to start towing before setting all shift mechanisms as required. Yes the initial expense is higher for the trailer but then you have at least partially offset the cost of the trailer and it is useful for so many other things. At my age (69) I certainly don't want to crawl around on the ground twice per trip for disconnecting a drive shaft.
DougE is offline
post #26 of 27 Old 09-21-2013, 06:49 AM
cj7ole
I feel very fortunate that ay my age (66), I don't mind crawling around on the ground to remove and reattach a driveshaft. Helps to have a 3.5" lift and a ground cloth. Not so fun when it is raining.
cj7ole is offline
post #27 of 27 Old 09-22-2013, 09:46 AM
DougE
1983 CJ7
Not so fun? Exactly my point!
DougE is offline
