Flat towing / tow bar /CJ-7 with Dana 300 Transfer case - JeepForum.com
post #1 of 27 Old 08-31-2013, 12:59 PM Thread Starter
GlennLever
GlennLever's Avatar
Can a CJ-7 be flat towed, towed with a tow bar, that has a Dana 300 Transfer case?
Will the bearings in the case get oiled, if the case is in neutral?
Do the drive shafts have to be disconnected?
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #2 of 27 Old 08-31-2013, 01:15 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
From the 1980 CJ-7 Factory Service Manual:
Recreational (Flat) Towing
Manual Transmission - D300
1) Ignition to OFF/UNLOCK position to unlock steering wheel
2) Shift Transmission into gear and Transfer Case into Neutral
3) Turn 4x4 hubs to LOCK for axle lubrication.
Most tow bars manufacturers recommend you DO NOT back up, so look for pull-thru parking spots.
CJ7-Tim is offline
post #3 of 27 Old 08-31-2013, 01:42 PM Thread Starter
GlennLever
GlennLever's Avatar
Never thought to look there, I have the manual for the 84, what section did you find that in?
Glenn R. Lever
My Web Site
post #4 of 27 Old 08-31-2013, 01:52 PM
gmakra
It depends on what transmission you have in the Jeep. The rear bearing on the output shaft of the trans may not get lube circulating if its in netural. The 300 will be fine no matter what trans you have.
gmakra is offline
post #5 of 27 Old 08-31-2013, 02:05 PM Thread Starter
GlennLever
GlennLever's Avatar
I have a T176 transmission and a Dana 300 Transfer case
Glenn R. Lever
My Web Site
post #6 of 27 Old 08-31-2013, 02:24 PM
LumpyGrits
Manual tranny....
Been flat-towing mine for 28+ yrs, all over the USA.
I disconnect the rear DS at the diff. pinion and hang it(tape the u-joint caps)up, under the body. T'case in 2WD and tranny in "N".
Don't forget to 'unlock' the steering wheel.
This takes less that 5 minute to do all the above, and will save an expensive 4 to 1 T'case.
I use a Smittybuilt tow bar(no longer made)mounted to a reinforced OEM stock bumper.
Tim-My OM('85)sez somedangthing about stopping every 125 miles or so, and start the engine to circulate the gear oil. You lock the hubs to 'lube' the t'case. NOT the axle.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #7 of 27 Old 08-31-2013, 03:52 PM Thread Starter
GlennLever
GlennLever's Avatar
I think what I will do is get a 16 foot enclosed trailer and tow it behind the RV. Solves the problem of getting under it to disconnect the drive shaft, not being able to back up because of the double pivot, junk getting picked up by the RV and thrown at the Jeep, and winter storage of the Jeep.
RV with the dragster trailer behind it.
Glenn R. Lever
My Web Site
post #8 of 27 Old 08-31-2013, 04:18 PM
CJ7-Tim
CJ7-Tim's Avatar
That's what the FSM says. Engaging the 4x4 hubs to turn the T-Case internals for lubrication is probably a more correct explanation. The procedure does vary slightly based on the automatic or manual transmission.
If the D300 Transfer Case is in Neutral, the Transmission will have no movement.
I prefer to disconnect the rear drive shaft from the diff, put the T-Case in Neutral, and leave the hubs in 2wd, and then nothing is moving.
CJ7-Tim is offline
post #9 of 27 Old 09-11-2013, 01:35 PM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Thanks Tim for the info. I called a local 4X4 shop and that is essentially the same thing they told me. I just finished a 600 mile round trip for a pronghorn hunt and flat towed the CJ-5 behind the van. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #10 of 27 Old 09-11-2013, 02:25 PM
CSP
Having seen a D300 that has caught fire from being flat towed I would throw what the factory service manual says out the window.
The output bearing on the D300 DOES NOT get any lubrication when being towed, regardless of what position the transfer case and/or transmission is in.
Here's another one that had a fire:
http://www.pirate4x4.com/forum/jeep-...ana-300-a.html
CSP is offline
post #11 of 27 Old 09-11-2013, 02:31 PM
LumpyGrits
Agree 110%. That's why I disco the rear DS at the diff
Also, the OM sez somedangthing about every 125 miles or so to stop and put tranny in gear and start the engine, or some such nonsense.
5 minutes of easy work pull'n the DS, to save my 4:1 t'case is a no brainer for me.
LG
post #12 of 27 Old 09-11-2013, 02:43 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I've flat-towed my CJ behind my RV for over 40K miles.
I've always put the t-case in neutral, trans in 4th gear, hubs and steering unlocked.
Right or wrong, I've never had a problem.
Matt
Matt1981CJ7 is offline
post #13 of 27 Old 09-11-2013, 02:53 PM
LumpyGrits
Good to hear you have had such good luck.
Just after see'n many 'smoked' when I know for fact they were towed as you do. I won't take the chance.
Just towed mine to Montana this last June. Sure nice to have along.
LG
post #14 of 27 Old 09-11-2013, 03:04 PM
Matt1981CJ7
1981 CJ7
After reading the thread that CSP posted, I may reconsider my towing practices and disconnect the rear driveshaft.
I guess you wouldn't rack up towing miles on the odometer that way, either, hmmm?
Matt
post #15 of 27 Old 09-11-2013, 04:29 PM
seabass1858
1983 CJ7
This was helpful because I will be flat towing my cj7 behind my camper to az from ga after its built. Thats 1800 miles.
seabass1858 is offline
