Flat towing a CJ-6 Chassis - JeepForum.com
post #1 of 3 Old 05-11-2011, 07:40 AM Thread Starter
billybob535
I am going to be towing my replacement CJ-6 chassis home from Ohio to NC (660 miles). It is a frame with axles, suspension, 232/T14/D20, driveshafts, exhaust, bumpers, grille, and a full frame mounted roll cage. I am going to be using a brand new towbar bolted through the stock steel bumper which is in good shape. The hubs will be unlocked and the driveshafts will be disconnected and tied to the frame. I will be flipping my hitch ball mount so the tow bar will be nearly flat while towing.
I have researched flat towing here and other forums and the consensus is that the steering must be unlocked on the towed vehicle. The CJ's tires, suspension, tie rod, drag link, pitman arm, power steering box, and rod ends are all in good shape and the jeep was in good alignment before the body was removed. The concern is that it does not have a steering column or steering shaft as the body tub has been removed. Getting a uhaul is out of the question for this trip.
Is the lack of a column/steering shaft going to be a problem when flat towing?
I would think it would not be since you are supposed to tow with the steering unlocked and intermediates didn't have locking columns anyways. Towing speed will be kept to a reasonable level. The tow vehicle weighs more than twice the towed vehicle and I will have safety lights on the back of the CJ.
Can someone here enlighten me.
Thanks
Bob
billybob535 is offline
post #2 of 3 Old 05-11-2011, 07:53 AM
CSP
Having no column is no different than leaving a locking column unlocked.
No need to pull the front driveshaft if the hubs are unlocked.
CSP is offline
post #3 of 3 Old 05-17-2011, 12:35 PM Thread Starter
billybob535
It towed just fine and the parts are now for sale. Just not here since I can't post to the classified forum. LOL
Thanks for the info.
Flat towing a rolling chassis - legal? Cutlass327 Jeep CJ Forum 15 03-28-2010 06:23 PM
Chassis paint, Gloss or Flat black? 76 CJ5 Jeep CJ Forum 7 01-29-2010 09:23 AM
Flat towing rolling chassis drespecki Jeep CJ Forum 7 08-25-2007 10:18 PM
Flat towing tncj Jeep CJ Forum 17 04-14-2006 10:10 AM
flat towing crusher Jeep CJ Forum 6 09-01-2004 05:56 AM
