Flaring Set Recommendation - JeepForum.com
post #1 of 8 Old 11-15-2012, 06:22 PM Thread Starter
MoC
Does anyone have a recommendation from personal experience for a brake / fuel line flaring set? Wanting to avoid a cheap set that brakes after a few uses. Been searching around a bit and have seen plenty of bad reviews.
MoC is offline
post #2 of 8 Old 11-15-2012, 06:33 PM
78FordF150
1983 CJ7
I have a Lisle brand that I have used for probably 15 years. Don't use it very often 15-20 times or so. Have had good luck with it. Lot better quality than you will get from Harbor Freight.
You can get them at O'reilly's around here.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #3 of 8 Old 11-15-2012, 06:41 PM
Fatman
Fatman's Avatar
2008 CJ7
Not sure brand mine is, but get one that is rated for stainless and will do double flares.
Thread Links:
Fatman is offline
post #4 of 8 Old 11-16-2012, 04:00 AM
gmakra
MoC if you have the money I would go with a Ridgid flare tool these are the Stienway's of flaring tools they are soild and all ways produce a great flare.
http://www.ridgid.com/Tools/345-Flar...l/EN/index.htm
gmakra is offline
post #5 of 8 Old 11-16-2012, 06:24 AM
cj783
1983 CJ7
2X on the Rigid set. Comes in a heavy duty blow molded case and makes great double flares or fuel line type flares/bulges or whatever they are called
cj783 is offline
post #6 of 8 Old 11-16-2012, 07:03 AM
lucdog
lucdog's Avatar
1980 CJ5
Mine is a Preformance tool W80670, I probably got it at a auto parts store, O'Reillys. probably done over 3 dozen flares with it. Haven't had a problem.
I've found , as with a lot of other things, practice makes perfect.
I would suggest the Ridgid tubing cutter. I have the close quarters one and the standard size. Don't cheap out on the cutter.
Bill
On edit, I haven't tried it on SS tube.
2nd edit. I've only flared 3/16" brake line with this tool. I just tried a 5/16" line, the small die wouldn't fit in the tube. The next size down was too small.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 8 Old 11-16-2012, 08:15 AM
lucdog
lucdog's Avatar
1980 CJ5
So based on my 2 edits, I wouldn't buy this tool again. It did do a 3/8" line ok.
Bill
3/8" tube
3/16" tube
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #8 of 8 Old 11-16-2012, 09:18 AM
jeepwhore
Bill
3/8" tube
Attachment 508459
3/16" tube
Attachment 508460
There's a comment to be made about that little tube between your legs but I'll just leave it at that........
I bought a cheapo set and haven't used it yet. Once I opened the case it didn't look like it could handle more than being looked at. It'll soon be replaced with something better.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
