Quantcast First timer - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > First timer
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 03-24-2009, 04:03 AM   #1
wetdog
First timer
Hey , this is my first post but its a burning question that maby some guru will know. I recently rebuilt my 258 in my 86 cj , it runs great except for onr thing if I idle for too long say 4 mins it starts to burn oil . As far as i can tell it might be the valve guides what do you think ? when driving around it burns nothing , passes smog , and uses hardley any oil between changes ??....thanks in advance .
wetdog is offline   Reply With Quote
Old 03-24-2009, 07:55 AM   #2
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
That sounds to me like it is choking out which blows black. I would open the air filter on a fully warmed up and running engine and make sure the air filter isn't full of oil as well as making sure the choke plate is straight up and down.
Did you mess with the carb mix screws and do you have all the stock emissions parts on there with the computer that runs them?
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 03-24-2009, 10:29 AM   #3
wetdog
Mike , I have the mopar fuel injection , I have checked all lines ..PCV and so forth for oil and found nothing . The only part I didn't do myself is the head which leads me to believe the valve guides have excessive clearance.Do you think that would cause this? Mark
Old 03-24-2009, 02:48 PM   #4
Mike Romain
Off Road Forever
Wouldn't that be more of a valve seal issue? If the valves leaked at idle, man just think what 4000 rpm would do to them. Parts would be flying...
I think it is more a tune thing...
Mike
Old 03-24-2009, 03:04 PM   #5
wetdog
The valves have those teflon seals as opposed to the umbrella type could that be it?
Old 03-24-2009, 03:09 PM   #6
Mike Romain
Off Road Forever
I don't know the difference in tolerances, maybe someone else does?
Mike
Old 03-24-2009, 04:53 PM   #7
Coiz
Coiz's Avatar
1979 CJ7
Leaking valve seals/guides usually gives you the puff of smoke at start up, not sure about extended idle.
Mike
My build thread
Coiz is offline   Reply With Quote
Glock Forum
