First Time Putting Hardtop On - JeepForum.com
post #1 of 7 Old 06-28-2013, 11:30 AM Thread Starter
jeep714
1981 CJ7
Unfortunately Massachusetts is supposed to get thunderstorms for the next week, spits time to put on the hardtop for the first time.
I got a hardtop reinforcement kit from quadratec, but since its never been on there are no holes in the windshield. Where do I drill the holes for the top?
Also, there's a black rail on top of the tub, where its at the highest point, and I'm not sure if that should be on or off when installing the top!
Peter
jeep714 is offline
post #2 of 7 Old 06-28-2013, 12:41 PM
Oily
The black rail will be for a soft top or bikini top. It is actually a channel of which the tops slide into, before you fasten 'em tight at the rear.
I haven't seen the Quadratec reinforcement kit. Original equipment had a metal strip which bolted to the windshield and also the top. I have never used mine. No water leaks when raining, no wind noise that I could hear over the other wind noise around the doors, . That reinforcement kit and my strip is just more work to do putting it on and off in my opinion.
Oily is offline
post #3 of 7 Old 06-28-2013, 06:37 PM
sanddrag
I've had my top on for a year or so and I still don't have anything joining it from the front of the top to the windshield frame. However, I'm thinking of bending a sheet metal plate to similar to the original because I can see it bounce and squeak a bit on the freeway sometimes.
sanddrag is offline
post #4 of 7 Old 06-28-2013, 06:46 PM
lucdog
lucdog's Avatar
1980 CJ5
The black rail has to come off. There should be 7 or so screws holding it on.
Don't drill any holes in the WS frame until the top is on, you might also remove the 2 large knobs that hold the windshield, for adjustment Purposes.
Depending on the year of your top, there will be either a fiberglass or metal strip that goes inside the WS frame. The screws go thru it, into the frame .
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 7 Old 06-30-2013, 07:37 AM
83vert
1982 CJ7
I'm putting my rail onto my windshield frame for my bikini top for the first time but I don't have any screws to secure it down. I guess just a short sheet metal screw will be fine? I don't want to strip out the holes because I plan on putting the hardtop on in the fall, is this what you guys are using?
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #6 of 7 Old 06-30-2013, 07:49 AM
keith460
Jeep. There's Only One
keith460's Avatar
Sheet metal screws are what 99% of Jeepers use for the front rail on soft tops and bikini tops but there is a better choice. I used, and so have a few others, 6 or 8-32 SS machine screws with a truss head. The windshield frame gauge steel is thick enough to drill and tap a hole for a 6 or 8-32 screw.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 7 Old 06-30-2013, 11:55 AM
83vert
1982 CJ7
Originally Posted by keith460
Sheet metal screws are what 99% of Jeepers use for the front rail on soft tops and bikini tops but there is a better choice. I used, and so have a few others,6 or 8-32 SS machine screws with a truss head. The windshield frame gauge steel is thick enough to drill and tap a hole for an6 or 8-32 screw.
That's a great idea Keith, thanks
I am in deep
83vert is offline
