DUI is said to be "The ultimate in ignition distributors is now available for your F & 2F equipped Land Cruiser. The DUI HEI ignition distributor is an all in one unit, that has a built in ignition module, and high energy coil. Hook up is made by a single 12v wire. Simply install this distributor, hook up a 12v wire, install a set of plug wires, set the timing, and you are done. No ballast resistors required, no points to set, or maintain, no coil to connect, and no ignition module to hook up. A tach terminal is provided on the distributor for those running a tachometer."
There are two types, one with a vaccumm advance and one purely mechanical. See if it has a vacuum capsule on the ide, I will presume it has. To get it going I would hook it up as follows:
Connect distributor vacuum advance to manifold vaccum or ported at the carb. Plug all other open ports.
Connect the red with tracer wire coming out of the bulkhead with the DUI wire.
Do not worry about the red with tracer wire coming from I on the solenoid.
Do NOT include the resistor in this circuit, you can cut it out.
When you turn the key it "should" start. Of course this depends if the rotor is pointing at #1 terminal in the cap at the same time as the #1 cylinder is nearing the top of the compression stroke, you have fuel and the sparkplug leads are all connected up.
Attached is a diagram of what you used to have so you can identify the wire coming out of the bulkhead connector that is your live wire 13B.
Yiu can junk all that wire apart from the light blue wire to the S tab and a red with tracer wire to the DUI. Yur choke and soleoind and engine control connections are all gone, as are the ignition control module and distributor pickup.
There are other ways to hook it up, say through a relay, that are better but this will get you up and running. the way to test the lead is to get a 12V test bulb and connect it to the wire and the -ve battery terminal. It should be bright in both Run and Start.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
BAGUSJEEP HAS GONE TO THE DARK SIDE OF GUCCI KIT - WEBER 38DGMS NOW NESTLES WITHIN
