First run with re-programmed TBI chip - JeepForum.com
post #1 of 24 Old 11-06-2013, 07:15 PM Thread Starter
243
1978 FSJ Cherokee
I took a shortcut and had Bill Hamilton program a chip so I can spend my time getting it buttoned up and road ready. I ran a dozen or more logs over the last month with the stock 4.3 V6 chip and once it was sorted out he used a V8 chip that provides synchrous fueling in lieu of a-synchrous fueling and disabled EGR and EST.
I am sure it can be fine tuned and I will send it back for tweaks later, but it runs freaking great, I was able to get out on the highway and up to 65 for a 1/2 mile or so plus another 30 minutes from 0-50.
It ran good enough to drive on the highway with the stock 4.3 chip so I am definitely starting to piece together a system for the Cherokee; I will also have Bill H program a chip to get me on the road.
If the weather cooperates I will be wrapping the dash harness this weekend so I can get the dash installed.
With the dash back in I can get it inspected and start driving it...getting close!
243 is offline
post #2 of 24 Old 11-06-2013, 09:18 PM
CSP
I'm not sure I follow you on the V6 vs V8 chip thing. If he's programming them I don't get it what vehicle/engine the chip came out of originally. The stock calibration codes become irrelevant at that point in my experience with live tuning.
CSP is offline
post #3 of 24 Old 11-07-2013, 01:41 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Programming chips, a-synchronous fueling, calibration codes....ugh....none of that sounds like a CJ to me.
I wish you luck, Dave, although I have no idea what you are doing.
Matt
Matt1981CJ7 is offline
post #4 of 24 Old 11-07-2013, 04:53 AM
gmakra
Matt jus cuz you use two soup cans and a string for your cell phone dosent mean everyone else does!
gmakra is offline
post #5 of 24 Old 11-07-2013, 05:14 AM
Matt1981CJ7
1981 CJ7
George,
Yeah, maybe I'm old-school.
But, after following Dave, Skipper, and Ken's fuel injection woes, I'm more convinced then ever to stick with my old fogger.
Matt
post #6 of 24 Old 11-07-2013, 07:01 AM Thread Starter
243
1978 FSJ Cherokee
I am not speaking with any first hand knowledge, only repeating and following what I have read.
It is my understanding GM used asynchronous fueling on the 4.3, I did not find any data that explains why the engineers programmed the system with this method. There is one BIN for the 4.3 that is synchronous but most of the people programming '7747 chips suggested starting with a synchronous 5.7 BIN for all applications, ASDU (5.7 Auto) or ASDW (5.7 Manual) one of the better BIN's.
I found one thread on GearheadEFI that goes into quite a bit of detail regarding asynch vs synch, it is far over my head so I am posting the link for you if you care to look at it.
http://www.gearhead-efi.com/Fuel-Inj...synch-fueling&
Originally Posted by Matt1981CJ7 View Post
George,
Matt
Matt,
The MC2100 that I bought to break-in my engine is probably the last carburetor I will ever buy for a car or truck. A TBI conversion is less complicated than I anticipated.
Look at the parts and pieces:
TB - Throttle body bolts on like a carburetor.
IAC - Idle air control sensor, already bolted to TB.
TPS - Throttle position sensor, already bolted to TB.
MAP - Manifold absolute pressure, one vacuum hose to manifold vacuum.
O2 - Oxygen sensor, one hole in the downpipe.
CTS - Coolant temperature sensor, screw it in just like an under dash temp gauge sensor.
ICM - Ignition control module, same hack as the stealth HEI or whatever it's called.
You say you are old school but you shoot a compound bow and they are not self-tuning
243 is offline
post #7 of 24 Old 11-07-2013, 07:18 AM
Matt1981CJ7
1981 CJ7
Originally Posted by 243 View Post
Matt,
That's very true.
However, my bow doesn't require a computer programming degree, or specialized equipment to tune.
As you can probably tell, I am intrigued by the FI conversion, or I wouldn't follow these threads. But, it just doesn't seem to be the "no-brainer" that some claim.
Maybe your final results, whenever you get there, will change my mind.
Matt
post #8 of 24 Old 11-07-2013, 07:58 AM
CSP
Matt you just have to dive in it. It's really no more difficult than the investment in time you took to fully understand your MC2100 and tuning the distributor.
For most it's plug and play, but you don't see threads about that. You only see threads where people want to dive in deeper and convert to live tuning or their own programmming. That or those that do have problems, most of which are pretty easy to diagnose. Think of all of the literally millions of GM cars out there still on the road with TBI that never have had a hiccup in regards to fuel induction.
CSP is offline
post #9 of 24 Old 11-07-2013, 08:09 AM
Matt1981CJ7
1981 CJ7
CSP,
I hear you. I'm sure I could figure it out.
Here's the thing. If I'm 30 miles deep into the wilderness and I have a carb problem, I'm confident I could diagnose and fix it with a screwdriver and a few basic hand tools. Not so much with FI.
Anyway, sorry for the derail, Dave. Carry on, and I will continue to watch and learn.
Matt
post #10 of 24 Old 11-07-2013, 10:51 AM Thread Starter
243
1978 FSJ Cherokee
Millions is right!
Do it Matt
243 is offline
post #11 of 24 Old 11-07-2013, 11:15 AM
Matt1981CJ7
1981 CJ7
Do it Matt
I will only if I'm forced to by emissions.
I don't really see it as an upgrade over a good running carb, at least for my purposes. I'm not reading many reports of huge performance differences, so it would just add another level of complexity to my engine.
But don't let that dissuade you at all. I'm just a stubborn redneck who likes tinkering with carbs.
Matt
post #12 of 24 Old 11-07-2013, 11:18 AM Thread Starter
243
1978 FSJ Cherokee
I have a NOS MC2100 I bought to break in my motor, if you are interested in a spare let me know.
243 is offline
post #13 of 24 Old 11-07-2013, 11:19 AM
CSP
There's definitely something to be said for a well tuned carb. At least until you point it uphill, which is why I learned about TBI. Choking, coughing, and sputtering trying to get out of the hot tubs on Hell's Revenge in Moab isn't a good combination.
CSP is offline
post #14 of 24 Old 11-07-2013, 11:27 AM
Matt1981CJ7
1981 CJ7
Thanks for the offer, but I don't think that will run too well on my 360.
CSP, I haven't been on a hill that's steep enough to drown my carb yet, and probably won't. I do understand, however, that is one of the benefits of FI for hard-core wheeling.
Matt
post #15 of 24 Old 11-07-2013, 06:15 PM Thread Starter
243
1978 FSJ Cherokee
Hey Matt, what other vehicles do ya'll have, the Jeep is not your winter vehicle is it?
243 is offline
