First rebuild - JeepForum.com
 1Likes
  • 1 Post By Matt1981CJ7
post #1 of 8 Old 09-26-2017, 03:56 PM Thread Starter
Avalanche724
First rebuild
So I have a 1986 cj-7 and am trying to do a rebuild on it every one else is telling me clean it up and sell to let it be someone else's problem but that's just not an option for me. So I'm just looking for a guide through it and tips and tricks and any money savers are BIG PLUS. Any help is appreciated.
IMG_0327_1506462706513.jpg   IMG_0330_1506462733631.jpg   IMG_0331_1506462756106.jpg   IMG_0333_1506462778239.jpg   IMG_0334_1506462796397.jpg
IMG_0335_1506462809831.jpg   IMG_0336_1506462829939.jpg   IMG_0341_1506462864143.jpg   IMG_0368_1506462877218.jpg   IMG_0367_1506462896630.jpg
Avalanche724 is offline
post #2 of 8 Old 09-26-2017, 04:35 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The first thing I'd do is address the coolant leak in cylinder 6.
Matt
Matt1981CJ7 is offline
post #3 of 8 Old 09-26-2017, 04:56 PM
pedal2themetai
1956 CJ5
HI .. I don't think he has a coolant leak the one plug is newer and different than the rest. looks like its not very bad..I can't see all 6 of the plugs but the plugs I see need changed very badly except the one newer auto lite plug.. the rest are Champion. The plugs just look sooty not wet with oil or anything Just in need of changing.. Can't tell what carb is on there.. I can see a header so someone may have put to big of a carb on it, It kind of looks like a 2100 Motor Craft, also the plugs look rich (being black sooty) from to much carb. Might need to re-jet the carb.
good luck
tim
pedal2themetai is online now
post #4 of 8 Old 09-26-2017, 05:06 PM Thread Starter
Avalanche724
I changed all the spark plugs and plug wires and put a new fuel filter on there I was trying to show that in the pics but that didn't work lol
post #5 of 8 Old 09-26-2017, 05:10 PM
firegod33
1977 CJ5
The clean plug is also a platinum. The rest are copper.
Looks like a good project base, to me. It already has an aluminum valve cover and the large distributor cap. Someone started making upgrades.
Earth first... We'll Jeep the other planets later.
firegod33 is offline
post #6 of 8 Old 09-26-2017, 05:46 PM
Matt1981CJ7
1981 CJ7
The PCV plumbing is screwed up, and I don't see a return line on fuel system, which could be the reason for the rich fuel condition.
OP, this is a good site to learn about your engine. I also suggest searching for a free download of the Factory Service Manual for your Jeep.
Those two resources should answer the majority of your questions.
Matt
pedal2themetai likes this.
post #7 of 8 Old 09-26-2017, 06:07 PM
pedal2themetai
1956 CJ5
Wow I didn't see that PCV mess up.. OP. the PCV connection at the back of the motor need to go to the air filter or have a filter element on it. It is for fresh air INTO the motor so the PCV valve at the front of the motor can pull out the fumes and such. It is NOT suppose to be hooked together. That alone can cause excess pressure inside the motor and cause gasket blow outs.
OH the other end of the PCV is suppose to go to the charcoal canister which might be missing..
good luck
tim
post #8 of 8 Old 09-27-2017, 07:23 AM
bob4703
1974 CJ5
Down load service manuals here http://oljeep.com/index.html
Paved roads are prime examples of government over spending!
bob4703 is offline
