Finding Exhaust Leaks with Smoke - JeepForum.com
post #1 of 2 Old 03-11-2004, 09:38 PM Thread Starter
ravinhuxley
Has anyone ever heard of using one of those bee smokers to find exhaust leaks? The thought occured to me about halfway home in my exhaust-induced haze.
It seems that you could place the smoker blowing into your exhaust and pump the exhaust line full of smoke. The reason I think it may not work would be not enough pressure to push smoke through small leaks.
Anyway, anyone have any feedback about this, why it may or may not work?
I checked Ebay, and you can find those smokers for $15. I would pay that if it would lead me right to my leaks.
'85 CJ-7
258|T-176|TFI|Weber 38 DGES w/Spacer|2" body lift|Centerforce clutch|A20|D30|32" BFG MTs|Red, of course
ravinhuxley is offline
post #2 of 2 Old 03-12-2004, 02:26 PM
mxg342
mxg342's Avatar
I don't know what all you have tried but the easiest way to find an exhaust leak is to get a buddy and do the following.
1 Start the jeep and leave it idling.
2 Have someone plug the exhaust pipe with a rag and press hard enough to stop the exhaust from coming out.
3 The other person should listen for whistling sounds coming out of the pipes. It should be pretty loud.
This way you don't have to get the smoker. Just a thought. HTH
Sorry if I mispelled anything. I had Lasik this morning and can't see too great yet.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
Black smoke from exhaust ,Why? (video) redcj576 Jeep CJ Forum 6 01-26-2010 06:30 PM
Exhaust smoke on my 360! BG33 Jeep CJ Forum 2 01-09-2010 01:41 PM
Changed out temp sender;engine/exhaust smoke ensues HoJoCJ Jeep CJ Forum 0 07-10-2008 06:20 PM
Exhaust smoke and no idle Weber 34 conversion daoliv Jeep CJ Forum 2 03-14-2007 10:42 PM
1977 258 exhaust leaks Jeff Johnston Jeep CJ Forum 2 07-28-2005 07:50 AM
