Fill a Fiberglass windshield? - JeepForum.com
post #1 of 11 Old 11-13-2009, 12:51 PM Thread Starter
awful8484
I replaced my CJ stock heater with an aftermarket heater and plenum. The pressure out of the front vents is powerful but sucks with the defrost. I think it has to do with the windshield being hollow and wasting pressure around the inside. Testing my idea I took the pivots out and stuffed rags in the corners and tested the defrost, pressure went up great. My question is, is there a reason you need to keep it opened up? Can I fill the corners with silicone to keep the air to the defrost vents?
awful8484 is offline
post #2 of 11 Old 11-13-2009, 01:17 PM
CSP
Personally I'd fill it with minimal expanding foam.
CSP is offline
post #3 of 11 Old 11-13-2009, 01:34 PM
Coiz
1979 CJ7
The stock frame has small plates in the ends to keep the majority of the air in the defroster area rather than traveling up the sides of the frame rail. They are not perfectly air tight but obviously help. I would seal up the ends too.
Mike
Coiz is offline
post #4 of 11 Old 11-13-2009, 01:53 PM
Mike Romain
I think I would fill it. That said, I have an open POS aftermarket frame and went with the big GM Blazer blower motor and can defrost all the windows, even at -30C in a snowstorm. It will clear that little center triangle and we don't need gloves or hats when driving at those temps. It is 'soo' nice!
The Blazer blower is a cheap and easy upgrade. Jeep Heater Blower Motor Upgrade
Mike
Mike Romain is offline
post #5 of 11 Old 11-13-2009, 05:08 PM Thread Starter
awful8484
Thanks everyone. I like the foam idea.. Ill do that. As far as the blazer upgrade, my heater core assembly was shot and I wanted something far easier anyway.
post #6 of 11 Old 11-13-2009, 06:05 PM
chet44
That's what I did, the foam I mean. Worked out really well. Of course I have a fiberglass frame.
chet44 is offline
post #7 of 11 Old 11-13-2009, 10:10 PM Thread Starter
awful8484
Chet44, did you notice a big difference filling the sides in with your defrost power on the fiberglass windshield frame? Is it clearing the window faster?
post #8 of 11 Old 11-14-2009, 05:56 AM
Mike Romain
But you say you have no defrost power.... The GM blower defrosts 'all' the windows, front, sides and back, even with a hollow windshield frame....
What brand of heater did you use?
Mike
post #9 of 11 Old 11-14-2009, 08:02 AM
chet44
The only difference I noticed was that the windshield cleared up a little faster. I'm itching to do the blazer motor upgrade though.
chet44 is offline
post #10 of 11 Old 11-19-2010, 03:46 PM Thread Starter
awful8484
Update:
It has been a year and I finally got around to filling my fiberglass windshield with expanding foam. What a huge difference it makes to have the sides filled, the defrost rocks out now. Another plus to this is I found a little screw holes on the top that I didnt know were there. Maybe that was also a big part of the problem.
With the heater idea, I tossed my stock heater assembly and went with the Danhard assembly. It works, but I want better. When I can scratch up the cash I would like to find the whole stock heater plenum assembly and do the blazer motor upgrade. If anyone knows of a stock heater box, let me know.
post #11 of 11 Old 11-20-2010, 03:28 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Let me look around the barn a little...
John Strenk is offline
Fiberglass windshield and bar mounting StewartCJ7 Jeep CJ Forum 1 10-15-2009 11:22 AM
Fiberglass Windshield Frame issues chet44 Jeep CJ Forum 15 12-02-2008 07:56 PM
Hardtop on Fiberglass Windshield Frame? TJTony Jeep CJ Forum 6 10-30-2007 11:20 AM
Fiberglass Windshield pf1130 Jeep CJ Forum 10 05-27-2005 04:43 AM
Fiberglass Windshield Marco Jeep CJ Forum 12 08-06-2003 09:14 AM
