Figure this out and you are a Jeep GOD; hesitation in traffic but runs fine on hwy - Page 2 - JeepForum.com
post #16 of 22 Old 08-05-2010, 02:31 AM
KMD
1976 CJ7
I am with Biotex and the EGR theory. It was the first thing that came to my mind. Especially if it idles really low.
KMD is offline
post #17 of 22 Old 08-05-2010, 11:23 PM
Jantelagom
1980 CJ5
I'm pretty new at auto repair, but I've been having similar acceleration problems in town and lower speeds that go away at higher speeds.
My brain went to the fuel system first but I changed my spark plugs, air filter and PCV filter and the problem has vanished. Good luck! Let us know what works.
Jantelagom is offline
post #18 of 22 Old 08-06-2010, 12:45 AM
carnuck
1984 J-Series Truck
EGR or maybe choke sticking?
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #19 of 22 Old 08-06-2010, 01:04 PM
Mike Romain
You have some good ideas to check out, just unplugging the EGR and blocking it's line is a fast test for that and i have seen the manifold gasket act like that.
There is also a $2.00 air filter on the gas tank vent that can cause symptoms like you mention when it gets plugged up. It puts a vacuum on the gas tank which starves the carb for fuel. Likely in need of a change anyway.
Mike
Mike Romain is offline
post #20 of 22 Old 08-06-2010, 03:17 PM
nshefbuch
1982 CJ7
i had a pin hole in the gas hard line once that only acted up when i stepped on the gas while driving. it would cruise all day below 40 but once i stepped speed up then it would putt around.
nshefbuch is offline
post #21 of 22 Old 08-07-2010, 03:52 PM
ReconRabbit
1983 CJ7
My first thought was a choke sticking also.
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline
post #22 of 22 Old 03-03-2013, 01:51 PM Thread Starter
Ch3ater
I know this is long overdue, but I wanted to thank everyone for their advice and guidance. I hope this post has helped some others with their fuel related issues. I’d like to run through what actions I took to tackle the problem (over the last 2 years in between deployments).
• First, I followed the fuel line routing to ensure they were not being overheated by the exhausts system. Good to go.
• The EGR was not sticking and I went ahead and pulled the exhaust manifold and replaced the gasket.
• Fuel filter was GTG.
• The gas cap is not of the vented type, since the tank vents through charcoal canister.
• The choke may have been sticking, in hindsight.
In the end, I decided to ditch the Carter and upgrade to a Howell TBI setup. Glad I did, but that’s not the end of the story. After install, the jeep ran phenomenally… for a week. She ran exceedingly well on short trips, but any longer trip lasting for more than 15-20 minutes would cause a ridiculous amount of pressure to build in the gas tank and the jeep would run extremely rough. I dropped the gas tank and found a return line crimped between the tank and frame. The CJ had been rear ended before all this started and the collision repair guys dropped the tank to replace the skid plate.
What I can say is that I learned a lot in the process and, for my frustrations; I got a Howell TBI out of it – which is outstanding IMO. And the lesson learned is NEVER LET ANYONE ELSE WORK ON MY CJ BUT ME (with the sound technical advice of this forum, of course).
Ch3ater is offline
acceleration stutter , hesitation , lag , nutter , overheat , vapor lock
Jeep runs fine then dies unexpectedly 21usmc47 Jeep CJ Forum 13 05-21-2008 08:39 PM
Jeep Ran Fine a Few Days Ago???? (Help) lhgdale Jeep CJ Forum 14 04-19-2008 10:03 PM
runs fine then stalls after warming up PrestonCJ5 Jeep CJ Forum 0 07-02-2007 08:35 AM
Jeep started fine and runs great now... onehundred Jeep CJ Forum 1 01-03-2006 09:02 PM
Starts fine, idles fine, but won't go.....can't figure it out fromme Jeep CJ Forum 4 08-04-2005 07:23 PM
