Figure this out and you are a Jeep GOD; hesitation in traffic but runs fine on hwy - JeepForum.com
post #1 of 22 Old 08-04-2010, 06:54 AM Thread Starter
Ch3ater
Iíve been in Afghanistan for a few months and when youíre in a place like this, you have a lot of time to think about stuff. And Iíve been thinking about my CJ7 a lot; where Iím going to drive it, what parts Iím going to buy, and all that. I canít wait to take my son for a drive out to the beach or around the base on the trails when I get home.
I have a question about the jeep thatís been on my mind and Iíd like to know where to start when I get home. Before I left, I was experiencing a strange problem that no one seems to have an answer for. Here goes.
Jeep starts and drives fine. Drives great for long distances, doesnít overheat, doesnít stutter or anything on acceleration.
However, when I drive it for 10-15 minutes, it warms up, and I get in stop and go traffic (usually on my way home from work) it begins to run very rough. Acceleration stutters and it feels like everything is just off, like itís trying to limp home. When I get it home and let it set for a few hours, it starts and drives just fine again.
The í84 CJ 7 is all stock, 4.2L 6-Cyl, Carter BBD Carb.
I have done these things so far:
1) It does not overheat, but: Changed thermostat, flushed cooling system
2) New fuel filter Ė checked carb jets (they are clean)
3) New Electronic Control Module, distributor cap/rotor, plugs, wires
4) Swapped out almost all the Vacuum tubing and rubber fuel line
5) Nutter Bypass because I thought it could be a computer problem
Thanks for taking the time to read this. Any thoughts?
Ch3ater is offline
post #2 of 22 Old 08-04-2010, 07:00 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Vapor lock? Maybe a fuel line run kind of close to some of the exhaust? At highway speed, ample air flow may be keeping the line cool enough but in traffic, heat builds up and the fuel begins to boil in the line causing symptoms similar to what you describe? I'd at least check fuel line routing to eliminate vapor lock possibility.
BESRK is offline
post #3 of 22 Old 08-04-2010, 07:09 AM
nitecop
I think you have a stuck or sticking heat riser valve. If your jeep has one of those.
If it gets stuck it will cause the carb to get very hot and probibily start boiling the fuel in the carb.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #4 of 22 Old 08-04-2010, 07:42 AM
BioTex
Welcome to the forum, and thank you for your service!
I think your problem is with the EGR. They get dirty and stick or just leak.
There is probably an EGR switch or a CTO switch involved in switching vacuum to the EGR once the engine warms up. I'll see If I can dig up a scematic of how it works, but for now I'd test the EGR by putting a vacuum to it with the engine running. See if the idle changes.
Edit: See the EGR CTO in the upper right? That senses coolant temp, and switches on/off vacuum to the egr. The switch seems to be working, but the egr opens and lets exhaust gasses into the intake. Try cleaning the EGR first. Could also be a source of a vacuum leak.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #5 of 22 Old 08-04-2010, 09:25 AM
swatson454
1983 CJ7
Many thanks for your service! My cousin is headed back there in just a few short weeks. Hence, my avatar.
I like Biotex's EGR possibility but I'd like to throw something else in the pot to ponder. I had a similar situation when I first got my Jeep. It would start up pretty well but within a few minutes it was running very rough. Let it sit for a few minutes and she was good to go.
Turns out the intake manifold gasket was bad. I guess as things started warming up, different metals and thicknesses would expand at different rates and the gasket would have a major vacuum leak. Let it heat soak for a bit and things would get to their final, expanded size and the leak would disappear.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #6 of 22 Old 08-04-2010, 10:22 AM
ctm
x2 intake manifold gasket and/or retorque all manifold bolts
ctm is offline
post #7 of 22 Old 08-04-2010, 10:23 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Sounds reasonble. Make sure your fuel filter is installed correctly. The filter should sit almost parallel to the ground and the 'vent' line should be on top. Make sure the vent hose is routed properly back to the gas tank and the line is not blocked.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #8 of 22 Old 08-04-2010, 10:29 AM
BioTex
Plugged vent on gas cap?
BioTex is offline
post #9 of 22 Old 08-04-2010, 10:31 AM
Shasta69
1978 CJ7
i think many here have any your jeep issues.
i will echo that thanks for your service. if it weren't for those brave Men and Women (like yourself) fighting over there... we'd be fighting these extremists here.
semper paratus!
uscg e8 retired
Shasta69 is offline
post #10 of 22 Old 08-04-2010, 11:32 AM
CJ8Extreme
1983 CJ7
Really sounds like a fuel issue/heat soak problem in a way. Stop and go driving elevates temps under the hood and fuel is not being pumped as fast through the lines. Like mentioned above, check your fuel filter and its oreintation and the fuel lines. Every sticking EGR valve that I have had caused a low/rough idle but always accelerated fine etc, but it is worth taking a look at.
CJ8Extreme is offline
post #11 of 22 Old 08-04-2010, 12:14 PM
GP75
Hey there, new member here. I've been using the heck out of the search function for my own issues, maybe I can help for a change.
My 85 CJ also has the Carter BBD. A few weeks ago, it was doing similar stuff. I had a new air filter element, but hadn't replaced the pcv filter that goes in the slot inside the filter housing. I pulled the PCV membrane and it was filthy. Put a clean one in and no more hesitation or shuddering.
Good luck.
GP75 is offline
post #12 of 22 Old 08-04-2010, 12:18 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Good luck.
Do you happen to have part number for the replacement filter?
Ken4444 is offline
post #13 of 22 Old 08-04-2010, 12:22 PM
CJ Chet
Sounds like you could use this:
http://www.civilianjeep.info/84-86FSM/CJ-FSM-84to86.pdf
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #14 of 22 Old 08-04-2010, 12:27 PM
Fixxxer_ZJ
Just spit-balling,but maybe the fuel is boiling in the carburetor.....
1998 5.9 Limited, CAI and Exhaust-My toy
2002 WJ Limited 4.7 HO, QuadraDrive-also mine :D
Fixxxer_ZJ is offline
post #15 of 22 Old 08-04-2010, 09:31 PM
GP75
breather filter link
Originally Posted by Ken4444 View Post
Do you happen to have part number for the replacement filter?H
Here is the one I used. Not sure if there is a different part
number.
Az Filters/Breather Filter | Breather Filter | 1985 Jeep CJ7 6 Cylinders C 4.2L 2BL | AutoZone.com
GP75 is offline
acceleration stutter , hesitation , lag , nutter , overheat , vapor lock
Jeep runs fine then dies unexpectedly 21usmc47 Jeep CJ Forum 13 05-21-2008 09:39 PM
Jeep Ran Fine a Few Days Ago???? (Help) lhgdale Jeep CJ Forum 14 04-19-2008 11:03 PM
runs fine then stalls after warming up PrestonCJ5 Jeep CJ Forum 0 07-02-2007 09:35 AM
Jeep started fine and runs great now... onehundred Jeep CJ Forum 1 01-03-2006 10:02 PM
Starts fine, idles fine, but won't go.....can't figure it out fromme Jeep CJ Forum 4 08-04-2005 08:23 PM
