Fiberglass windshield and hardtop???????? - JeepForum.com
post #1 of 8 Old 02-17-2010, 04:16 PM Thread Starter
acnflorida
How do I fasten my hardtop to my fiberglass windshield?
acnflorida is offline
post #2 of 8 Old 02-17-2010, 04:39 PM
Galt
Galt's Avatar
1983 CJ7
I don't tighten my hardtop at the front to the metal windscreen frame. So long as it's bolted down to the tub it should be fine. It doesnt leak water either.
If you still want to you could run screws through the interior metal lip on the top and into the window frame.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #3 of 8 Old 02-17-2010, 08:27 PM
jm708
2014 JK Wrangler
I also have the same set up and didn't secure the front. Its been driven at highway speeds and around town all winter with no problems. Make sure its tight on the tub and it should be good to go.
jm708 is offline
post #4 of 8 Old 02-18-2010, 05:39 AM
jscherb
My windshield frame isn't fiberglass, but these latches should work with a fiberglass frame too. You can find latches like this at the McMaster-Carr website.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #5 of 8 Old 02-18-2010, 06:01 AM
Mike Romain
I like the latches! Right now I have a footman loop on the hardtop that matches the one on the top of the frame so I just run a couple hose clamps between them or plastic zip ties. As others have noted, it doesn't leak.
Mike
Mike Romain is offline
post #6 of 8 Old 02-18-2010, 06:51 AM
_Kyle_
_Kyle_'s Avatar
Mine's not attached to the windshield frame but is just fine.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #7 of 8 Old 02-18-2010, 09:53 AM
crcj7
neather is mine
geter done goter did flipeder over didit agian
i need an nv3550 any one need a hardtop
crcj7 is offline
post #8 of 8 Old 02-18-2010, 04:20 PM
cjjon7
1983 CJ7
Mine leaks air like a bastard and rattles like crazy over bumps, but probably due to the fiberglass tub not being identical to factory..oh well..
cjjon7 is offline
Mounting hardtop to fiberglass tub bill in the hil Jeep CJ Forum 13 11-21-2011 09:03 PM
Fill a Fiberglass windshield? awful8484 Jeep CJ Forum 10 11-20-2010 03:28 AM
Hardtop on Fiberglass Windshield Frame? TJTony Jeep CJ Forum 6 10-30-2007 11:20 AM
Fiberglass Windshield pf1130 Jeep CJ Forum 10 05-27-2005 04:43 AM
Fiberglass Windshield Marco Jeep CJ Forum 12 08-06-2003 09:14 AM
