Fiberglass tubs - cutting a tailgate out? - Page 2 - JeepForum.com
post #16 of 26 Old 07-21-2013, 10:58 PM
Skerr
I have a glass CJ where the PO had cut and installed a tailgate. He didn't do a good job. I closed the hole back up and made it solid again. Then I repaired all the cracks after all the flexing the body had done. You're going to have that somewhat anyway, but I think it is worse with that big gaping hole back there. That being said, do what you want. Make it look the way you want it to look.
When the term frame was mentioned, many tubs have 1/4 plywood sandwiched between the inner and outer layers to give it more stiffness or for mounting points. The plywood is found in stress areas. If you cut a hole, be sure and seal it up good so it doesn't get wet. It will rot between the glass layers.
A cutoff wheel is the best thing to cut glass accurately. It will not burn the glass. It will make dust! Cover yourself up as much as you can bear, then liberally dust yourself with baby powder anywhere you have exposed skin. The baby powder will help keep the dust out of your pores.
Last thought... if you use a tire carrier nobody will ever see your tailgate!
Good luck.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #17 of 26 Old 07-22-2013, 05:33 AM Thread Starter
HeathFinnie
1976 CJ5
I have thought about the tire carrier VS. tail gate situation. I don't want to mount a tire carrier to the tub for obvious reasons... And good bumper mounted carriers or other work arounds?
HeathFinnie is offline
post #18 of 26 Old 07-22-2013, 07:29 AM
Jeeprage
Jeeprage's Avatar
Good luck.
Cut off was what you told me and it worked perfectly.
That is the reason i don't have a spare yet. I love reading Jeep as i walk up.
2015 JKU - 6m
Jeeprage is offline
post #19 of 26 Old 07-22-2013, 03:14 PM Thread Starter
HeathFinnie
1976 CJ5
Does anyone have some good bumper mounted spare tire suggestions?
I do agree with Jeeprage, I'd just love to walk up and see Jeep on the back.
post #20 of 26 Old 07-22-2013, 07:29 PM
OrangeCJ-5
1978 CJ5
Tailgate vs no tailgate is personal preference. If you like the tailgate look and have the skill to do it I'd say go ahead. My CJ5 doesn't have a tailgate and liked the look which is another reason I bought it. I don't see much use for one on a '5' with a back seat.
OrangeCJ-5 is offline
post #21 of 26 Old 07-22-2013, 10:53 PM
Skerr
That's classic, Rage!! I can see how you feel.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #22 of 26 Old 07-23-2013, 05:29 AM Thread Starter
HeathFinnie
1976 CJ5
There's a body shop near me where I know there are some Jeepers as well. I might go talk to them and see what there opinion is as well.
post #23 of 26 Old 07-23-2013, 05:30 AM
Jeeprage
Jeeprage's Avatar
It just goes so well with CJ7 and AMC badges.
2015 JKU - 6m
Jeeprage is offline
post #24 of 26 Old 07-25-2013, 07:28 AM Thread Starter
HeathFinnie
1976 CJ5
Is there a good way of identifying the brand of tub that I have? I'm curious as to what brand it is and where it was made.
Thanks!
Heath
post #25 of 26 Old 07-26-2013, 07:15 AM
Skerr
Thanks!
Heath
None that I am aware of... I have no idea what mine is. It is "older" though, and it was pretty beat up when I got it. It used to bug me, but I am over it!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #26 of 26 Old 07-27-2013, 11:59 AM
sbcranger
I have an older 4wd tub and there is a part number tag on the bottom of the cowl in the passenger area on the drivers side. I think it was actually sealed in with resin if I remember correctly
sbcranger is offline
