Fiberglass tubs - cutting a tailgate out? - JeepForum.com
post #1 of 26 Old 07-21-2013, 07:31 AM Thread Starter
HeathFinnie
1976 CJ5
I have a glass tub on my CJ5. I have also come into a nice original tailgate. I imagine someone has cut a tailgate opening and attached one to a fiberglass tub that did not have one originally? Any tips? Is it difficult?
HeathFinnie is offline
post #2 of 26 Old 07-21-2013, 11:35 AM
thantos858
1974 CJ5
Which fiberglass tub? Most of them have a frame inside the glass that helps strengthen the tub. If you cut that frame you'll weaken the tub a lot.
thantos858 is offline
post #3 of 26 Old 07-21-2013, 11:50 AM Thread Starter
HeathFinnie
1976 CJ5
How do the tubs with the cut out already made get around it?
post #4 of 26 Old 07-21-2013, 12:31 PM
sbcranger
They have different structural support for the two different tubs. Think of it similar to a hardtop and convertible cars
sbcranger is offline
post #5 of 26 Old 07-21-2013, 12:42 PM Thread Starter
HeathFinnie
1976 CJ5
So in other words, I really shouldn't do it...
post #6 of 26 Old 07-21-2013, 12:44 PM Thread Starter
HeathFinnie
1976 CJ5
I was thinking of cutting it and then reinforcing the sides that I just cut and re-fiberglassing the sides to make it look professional
post #7 of 26 Old 07-21-2013, 01:41 PM
LumpyGrits
Hole saw or a 'Sawzall'.
That 'glass' is a blade killer.........
LG
LumpyGrits is offline
post #8 of 26 Old 07-21-2013, 01:51 PM
Jeeprage
Jeeprage's Avatar
What do you mean by frame? My 4wd tub with tailgate cut out has metal plates glassed in for swing out carrier, but that is it. He could glass in additional support inside.
Use a grinder with cutting disk to cut the glass and wear a mask. My rockers trimmed up perfectly.
2015 JKU - 6m
Jeeprage is offline
post #9 of 26 Old 07-21-2013, 02:53 PM
sbcranger
i don't know what thantos858 was meaning by a "frame", but its actually how they set up the fiberglass and the thickness of the fiberglass in key areas. the tubs with the tailgate cut out is substantially thicker and stiffer in the rear panel than a tub without the cut out.
its entirely possible to take a tub without a cut out and do it yourself, it's just a question of how much of your time and money is worth to put in a tailgate...
just think out the work that will have to be done to achieve putting in a tailgate:
you have to brace the tub so it doesn't get twisted when you cut out the section, then prep and glassing in the new tailgate cutout.setting up the hinge mounts. fit and finish then paint or gelcoat etc. etc.
and cutoff wheels are probably the preferred tool to cut fiberglass but they make a hell of a mess.
post #10 of 26 Old 07-21-2013, 02:59 PM
LumpyGrits
You do NOT ever want to use an abrasive cut-off wheel on f'glass. It will burn the 'glass'. You want to saw it.
Even with a saw-Wear a dust mask-That 'dust' is a known killer.
Take a shower when done to get the 'dust' off of your skin.
LG
post #11 of 26 Old 07-21-2013, 04:03 PM Thread Starter
HeathFinnie
1976 CJ5
How would I find out which brand tub I have? It was done before I got it...
post #12 of 26 Old 07-21-2013, 04:58 PM
thantos858
1974 CJ5
Guess technically it is a frame since its normally thicker parts that have been reinforced to support the body.
Use a saw blade to cut fiberglass since you don't want to burn it. After you cut the opening sand it down and the gel coat then reinforce it from there. It will take a lot of time to get it right.
post #13 of 26 Old 07-21-2013, 05:10 PM
BootheelBoy
I understand this thread is about putting in a tailgate not if you should or shouldn't. Other than making the jeep look more original I don't see much of a benefit. My CJ7 has only had the tailgate dropped about three times in the last 12 years. To me it just wouldn't be worth the hassle and possibly damaging an nice tub. If you decide to do it please take pics. I am an idiot when it comes to fiberglass and would love to see how it's done.
BootheelBoy is offline
post #14 of 26 Old 07-21-2013, 05:43 PM Thread Starter
HeathFinnie
1976 CJ5
This thread is a little of both. I have a great original tailgate that I could use and I LOVE the more original look of the Jeep with the tailgate than the fiberglass tub without it which I think looks empty.
That being said, if I can make it work I'd love to do it, but if I can't I will suck it up. It just seems like something that could be done seeing as there are fiberglass tubs with tailgates.
I do see what people are saying though about tubs being made with tailgates being made with a different standard than those without… Just seems like it could be done and might make a fun project.
post #15 of 26 Old 07-21-2013, 06:09 PM
2xCross
I had a tub that someone cut the tailgate into it. The issue I had was it needed to have all the beveled parts for the tailgate seal to fit against. I agree the jeep tub does look better with a tailgate, but the fit and finish looked like it was tons of work so I just reglassed the tailgate opening in.
2xCross is offline
