Fiberglass Hardtop - JeepForum.com
post #1 of 11 Old 08-28-2011, 12:55 AM Thread Starter
cmburrell
Fiberglass Hardtop
I have a decent crack in my hard top I'd like to fix it and repaint my hardtop. Its black now and not in bad shape at all except for the crack. I have no experience with fiberglass repair. How difficult is it and any suggestions on how going about doing it. My only real wonder is how to sand it.
cmburrell is offline
post #2 of 11 Old 08-28-2011, 06:52 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
You might have to sand the whole top to get it to look good.
Here is a page of a guy rebuilding an ACME top. The principals are the same.
http://www.manoian.net/jeep/acme_hardtop.html
Hope that helps,
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #3 of 11 Old 08-28-2011, 10:37 AM
Cutlass327
1978 CJ5
Also look in my "Fiberglas Tub Modification" thread. there are some tips there on basic fiberglass work, also a link to Skerr's thread on his son's build, where they are doing a bunch of 'glass work. These tips are more of the generalized how-to for 'glass, but you can adapt it to the HT. Especially in Skerr's thread, where they are doing the hood.
http://www.jeepforum.com/forum/f8/fi...-easy-1246228/
Where they start getting into the hood:
http://www.jeepforum.com/forum/f8/cl...7/index32.html
Rick
Cutlass327 is offline
post #4 of 11 Old 08-28-2011, 01:25 PM
Dkilby95
i'd get some cats hair fiberglass, put that on the crack and then sand it down to flat
Dkilby95 is offline
post #5 of 11 Old 08-28-2011, 03:34 PM
Mike Romain
How bad and where is the crack?
My stock top is an eggshell finish, so a fill and sand will show.
if the crack is structural, then grinding it out in a wide V shape and putting thin layers in is the best. For 1/8" deep grind, you need about 1 1/4" wide shallow V, then you use a 1/4" strip to start and a 3/4-1" top strip.
I would then sand it a bit low and use a roller or sponge to try and get some eggshell finish with primer before painting to match.
Mike
Mike Romain is offline
post #6 of 11 Old 08-29-2011, 07:02 PM Thread Starter
cmburrell
Hope that helps,
Jeff
Thanks Jeff the link really gave me a lot of useful info
post #7 of 11 Old 08-29-2011, 07:02 PM Thread Starter
cmburrell
Thanks the thread was very interesting. I love how you did the gas filler.
post #8 of 11 Old 08-29-2011, 07:05 PM Thread Starter
cmburrell
The crack is right above the passenger side door starting at the drip edge traveling up about 4 to 5 inches. I also plan on painting the entire top afterwards so Im going to sand the whole thing and remove the original finish but I'm wondering what I should go back with do you suggest eggshell.
post #9 of 11 Old 08-29-2011, 07:39 PM
Dborns
The hardtop I bought had cracks below both side windows that were held together by metal strapping. Without any previous fiberglass work, I was able to fix it so that you can't even tell there was damage to the top. I sanded the damage down about 4" around the damaged area, and a little more at the crack itself. Be careful with the sanding disc, as it can get out of hand pretty easy. I then used fiberglass mat and fibers according to the instructions to fix the area. Its easy but messy. I painted the whole top with RustOleum black. Good luck.
Dborns is offline
post #10 of 11 Old 08-29-2011, 08:50 PM Thread Starter
cmburrell
Thanks the project will start tomorrow with the sanding based on all the info I've gotten I feel pretty good about it.
post #11 of 11 Old 08-30-2011, 12:35 AM
Cutlass327
1978 CJ5
FYI - I think you were thinking of Clay's thread on the gas filler - mine's always been the stock style..
Rick
Fiberglass hardtop to a fiberglass body. BigPapaCJ Jeep CJ Forum 8 03-12-2013 02:29 AM
Mounting hardtop to fiberglass tub bill in the hil Jeep CJ Forum 13 11-21-2011 09:03 PM
CJ7 hardtop fiberglass repair w/pics Tigerpaw Jeep CJ Forum 4 10-25-2010 11:28 AM
Fiberglass windshield and hardtop???????? acnflorida Jeep CJ Forum 7 02-18-2010 04:20 PM
Hardtop on Fiberglass Windshield Frame? TJTony Jeep CJ Forum 6 10-30-2007 11:20 AM
