Fiberglass Hard Half Door Question - JeepForum.com
post #1 of 8 Old 09-26-2010, 11:16 AM Thread Starter
GSSFC
I have a set of fiberglass hard half doors. They fit the door opening perfectly, but the latches are wrong. I can't seem to ID the door or the latches to see if I can get a replacement latch to make this setup work.
I have full hard doors I use in the winter, so I need to make a 'non-permanent' fix to make them bosh work.
Here are the pics of the half doors.
Thanks, Tim
GSSFC is offline
post #2 of 8 Old 09-26-2010, 12:20 PM
Robyjuk
1987 YJ Wrangler
looks like a set of aftermarket doors to fit an early cj
Robyjuk is offline
post #3 of 8 Old 09-26-2010, 12:51 PM Thread Starter
GSSFC
So, can I get a different latch for the door or a different latch for the tub to make it work?
Tim
GSSFC is offline
post #4 of 8 Old 09-26-2010, 01:18 PM
Robyjuk
1987 YJ Wrangler
you may be able to find a aftermarket/ kit car doorlatch that will work with them,we have them over here in the uk but not sure if you have them in the states.. you could try to fit a later lock mechanism but you would need to be good at fibreglassing and fab.
Robyjuk is offline
post #5 of 8 Old 09-26-2010, 01:42 PM
Pathkiller
1974 CJ5
"early cj"?? I'm assuming you mean a 76-81 CJ7, with this style of latches. An "early CJ" is a 1946 CJ2A, which these doors obviously won't fit.
Pathkiller is offline
post #6 of 8 Old 09-26-2010, 03:20 PM
Robyjuk
1987 YJ Wrangler
yup sorry but i thought it was obvious as it was a question about 7's not a CJ2A.
Robyjuk is offline
post #7 of 8 Old 09-26-2010, 09:29 PM
jp360cj
1977 CJ7
The early '7 doors didn't use a latch, just use the door jam. I'm hoping you can unbolt the door latch from the tub and bend a piece of metal to fill the recess in the door jam. My cousin has the same issue with his '83 and that's what we're going to try.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 8 Old 04-10-2011, 01:57 PM
jarrodblake
1978 CJ10
bumping this thread, i just bought the same doors, and i was wondering if anyone found out who makes them? also i see the the first pic you have a fitting for upper doors can i use any upper door on them or do they make a upper door just for these?
jarrodblake is offline
CJ7 Hard Door Question jeep8821 Jeep CJ Forum 6 11-25-2009 11:30 AM
scrambler half hard top question daltonw Jeep CJ Forum 17 11-06-2009 07:04 AM
81 Hard Door question RenegadeKing81 Jeep CJ Forum 4 11-06-2008 05:53 PM
CJ half door question SOUTHGACJ Jeep CJ Forum 1 06-15-2004 10:04 AM
Half Fiberglass???? cj5mudman4x4 Jeep CJ Forum 4 01-16-2003 06:40 PM
