Fiberglass body mount heights - JeepForum.com
post #1 of 5 Old 01-03-2004, 01:58 PM Thread Starter
78GlassCJ5
I am getting ready to put back on my fiberglass cj5 body. I have the frame and engine all restored, but am not sure what heights the rubber body mounts should be cut at. The rubber tubing mounts that were on there are all different sizes. I just want 1" lift from it.
Are all the mounts the same height? or are they different depending on the location of the mount??
THanks in advance,
D
78GlassCJ5 is offline
post #2 of 5 Old 01-07-2004, 02:07 PM
muddy00
Depends on the body brand, I know on my 4wd hdw ont you cut the one's under the doors first then then measure and cut the others, I think you start @2 " for the 1st one. Call 4wd harware tech support to be sure
muddy00 is offline
post #3 of 5 Old 01-07-2004, 02:20 PM Thread Starter
78GlassCJ5
Thanks, I called 4wd hardware, and they said that the 2 and 3 mounts (the ones under the rear seat area) are supposed to be cut to 2 1/8" then cut to fit the rest leaving 1/8" for compression.
D
post #4 of 5 Old 01-10-2004, 07:36 AM
Twystd
1980 CJ5
I put on a glass body on my CJ5 from 4wd hardware, I didn't like the look of my Jeep with what the company said they should be, looked too much like a body lift, cut mine in half and it looks good....
My CJ is your Wrangler's Daddy!
Twystd is offline
post #5 of 5 Old 01-12-2004, 07:04 AM
HIPPER
HIPPER's Avatar
Yeah, 4wd told me that 2 1/8 would give me about 1" body lift. I didn't want that so I cut them at 1 1/8. It turned out just how I wanted it. It was tricky, take your time and measure a couple of times. I think you do the front mounts last. If you tighten the front down and then the back, the bolts will pull right through the fiberglass in the front.
I have pics if you want to see mine. bhipp@clevelandbrowns.com
HIPPER is offline
Pics of fiberglass body mount lacpa Jeep CJ Forum 3 03-11-2015 07:30 PM
Do i need this to mount my fiberglass body? Arcticcat843 Jeep CJ Forum 18 06-30-2009 06:24 PM
fiberglass body mount bushings blutowski Jeep CJ Forum 3 04-20-2009 02:08 PM
fiberglass body mount kit? help blacklabel000 Jeep CJ Forum 5 03-07-2008 02:01 PM
WHy can't you do a body lift with a fiberglass body supraman1990 Jeep CJ Forum 6 08-03-2007 09:47 PM
