Fender Tear - JeepForum.com
post #1 of 5 Old 02-19-2012, 01:26 AM Thread Starter
leeherron
1981 CJ8
Fender Tear
'81 CJ-8 Frame-Off in progress.
Looking at my untouched fenders, it appears that the results of a design flaw have cropped up - and I expect some of you have seen the same issue.
The ripple and light tearing of sheet metal at the fold seam just a few inches away from the mount.
What did you do about it?
leeherron is offline
post #2 of 5 Old 02-19-2012, 03:36 AM
my_304_cj7
1976 CJ7
What I did was very labor intensive. I drilled out all the spot welds and fabbed up a new one. But mine had some rust issues and yours look pretty good.
What you could do is pound it back down flat and weld the tear.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #3 of 5 Old 02-19-2012, 06:33 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
tube fenders, thats my plan lol
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #4 of 5 Old 02-19-2012, 07:25 AM
gmakra
You could drill the ends of the crack with a small drill bit. What this does is it disperses the stress in a radial patern and stops the craki from spreading.
Then weld it with a MIG unit with .024 wire weld with short pulses so you dont burn through, Grind and put a little body filler on and your good to go.
gmakra is offline
post #5 of 5 Old 02-19-2012, 09:34 AM Thread Starter
leeherron
1981 CJ8
This is what we've done so far ..
Straitened out the metal, welded the tear and added upper & lower support using 16ga galvanized steel.
I'll post a couple more pics of the finished process tonight.
cj , fenders
How to tear down a CJ in 4 minutes Curt Reinhardt Jeep CJ Forum 12 09-11-2010 04:47 PM
How do I tear this down to powdercoat? CJman77 Jeep CJ Forum 3 03-20-2009 05:29 PM
Starting Tear down. few ??? dblock16 Jeep CJ Forum 18 12-21-2007 04:50 PM
And the tear down begins Gixxed Jeep CJ Forum 2 10-23-2006 06:00 AM
