Fender Problem - JeepForum.com
post #1 of 9 Old 01-27-2010, 08:54 PM Thread Starter
mjeckell
1979 CJ7
Fender Problem
I have a 1979 cj7 304 california model. I just got done painting my vehicle and spraying the wheel well of the fenders. Everything was in pieces. The fenders are replacement fenders that I bought from morris 4x4. They are steel. My problem is I tried to attach the driver side to the tub and grill today and the inner well hits the smog pump. Has anyone ran into this situation? What did you do to rectify the situation? Also the notch that was made for the shock bracket is in the wrong spot. I really screwed up by not checking this stuff before final paint.
mjeckell is offline
post #2 of 9 Old 01-27-2010, 08:57 PM
Coiz
1979 CJ7
I've seen people trim them for the shock mount, had not heard about the smog pump problem. Probably because 98% of the CJ's out there no longer have the smog pumps installed.
Mike
Coiz is offline
post #3 of 9 Old 01-27-2010, 09:01 PM Thread Starter
mjeckell
1979 CJ7
well I need to have the smog pump since it is in california. I cant believe that this has not been posted since all jeeps that are in california must have this equipment on.
mjeckell is offline
post #4 of 9 Old 01-27-2010, 09:11 PM
Chuckles0227
1980 CJ5
the shock cut outs are wrong on my repli fenders too, but i don't have a problem with them. All of the holes still lined up on the grill, and the fender just rubs the shock tower a little bit.
"If you sit when you pee, go with the square headlights..." - tawdr77
Chuckles0227 is offline
post #5 of 9 Old 01-27-2010, 09:20 PM Thread Starter
mjeckell
1979 CJ7
Yeah I dont think I am gonna have a problem with the cut-outs any longer. I just need to find a solution to the smog pump. I cant cut that portion of the fender out. That would expose the smog pump and belts to inside the wheel well.
mjeckell is offline
post #6 of 9 Old 01-28-2010, 07:02 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I thought you guys on the west coast didn't need to replace fenders due to not having any rust...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #7 of 9 Old 01-28-2010, 07:05 AM
certifiablejeep
Bicentennial Nickel
1976 CJ5
Sorry, couldn't resist that one... we go through fenders like boots out here. So, I am not all that familiar with the smog pump issue, but is it rubbing, or is it one of those things that you can take the pump off, put the fender on and then put the pump back on and you would be OK?
I am at work and can't see any pictures right now, so I am not sure if you posted any, but from the description, it is hard to tell exactly what the issue is.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #8 of 9 Old 01-28-2010, 09:05 AM Thread Starter
mjeckell
1979 CJ7
No the smog pump is definitely in the way. I am have thrown away the old fenders months ago. They were that bad. I am assuming the combo of the smog pump as well as the 304 is the issue. I am also assuming that they had to make a different fender for this california jeep. I wish that I had some pictures of the old fender inside.
mjeckell is offline
post #9 of 9 Old 01-28-2010, 09:33 AM
trailhead2004
1980 CJ7
cb
For the most part you are right but some people living on the coast have to deal with the salt air.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
75 CJ-5 fender on 80 CJ-7 4XGore Jeep CJ Forum 2 12-12-2008 12:12 PM
cj fender aero mech Jeep CJ Forum 3 03-10-2008 11:29 AM
Fender ? cj71983 Jeep CJ Forum 4 12-18-2007 09:26 PM
I want ur fender got4-Lo Jeep CJ Forum 3 12-09-2004 07:08 PM
Fender liftedred84cj7 Jeep CJ Forum 3 05-12-2003 07:47 PM
