Fender Flap - JeepForum.com
post #1 of 2 Old 03-02-2012, 03:19 PM Thread Starter
leeherron
1981 CJ8
Fender Flap
'81 CJ-8 Frame-off
So prepping the fenders for paint .. I've seen small rust colored stains in this spot on CJ's out there before .. the oddly placed flap of metal that wraps the rear bottom section of CJ fenders (see photos).
What have you guys done to deal with this for paint?
leeherron is offline
post #2 of 2 Old 03-02-2012, 04:03 PM
Always2L8
1982 CJ8
I generously brushed/worked Ospho metal treatment into the seams as best as possible. Gave it a long time to dry - even helping it a bit with a heat gun. Epoxy primer was brushed into the seams - not only around the outside but also any inside seams. The fender was spayed with epoxy primer and any seam or lap that looked like water could get into was filled with 3M seam sealer. Normal primer was then sprayed prior to the paint top coat.
It's been 5 years and appears to be holding. Yours seems to be in good condition.
Good Luck
Always2L8 is offline
cj , fender
what is the hinged flap in the cowl for? John87 Jeep CJ Forum 8 01-30-2012 06:22 PM
Wire wheel and flap disc help Skerr Jeep CJ Forum 21 05-22-2010 08:00 PM
Reinstalling Heater Housing....Mystery Flap connor014 Jeep CJ Forum 8 12-08-2009 09:11 PM
258 Stock Air Intake Question (Flap linkage) PearlRiver Jeep CJ Forum 5 01-30-2009 10:38 AM
