Favorite way of replacing clutch? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Favorite way of replacing clutch?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-15-2015, 08:57 PM   #1
1980tallcj7
1980 CJ7
Hey y'all,
I recently developed a problem with either the pilot bushing/ bearing or the throw out bearing . The symptom is a chattering /screeching/ vibration when I press the clutch in while throttling up the engine, like when you blip the throttle for a downshift.
So, curious what everyone's favorite method is for changing the clutch. Engine out?, or pull the transfer case and transmission from underneath?
1980 CJ7, Mule
1980tallcj7 is offline   Reply With Quote Quick reply to this message
Unread 08-15-2015, 09:32 PM   #2
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I would leave the engine in. Remove the drive shafts, use a transmission jack to support the trans, unbolt the bellhousing from the engine, pull the trans and transfer case away from the engine. Replace the pilot bushing/bearing while you're in there.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is online now   Reply With Quote Quick reply to this message
Unread 08-15-2015, 09:56 PM   #3
only in a jeep cj
Folks seem to be very divided on this topic. Some prefer to pull the transmission and tcase together and or even leave the bellhousing on the transmission. Some prefer the transmission jacks etc.
Ive done a ton of these and for me, I prefer to use one jackstand and a floorjack. I support the tcase with the floorjack, remove bellypan, support under trans with jackstand, remove t case, support under bellhousing and remove trans, then bellhousing. EACH one can be easily removed by hand and replaced the same way allowing for easy spline line up.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 08-15-2015, 11:53 PM   #4
RedNeckCorvette
1979 CJ7
I have done them each way but like to pull the motor.
RN
RedNeckCorvette is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 04:09 AM   #5
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I prefer to remove the motor. Working from the top is way easier in my book, plus I live in the rust belt where skid plates seldom come off and go back on without serious trouble. Snapped or spun bolts.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 07:05 AM   #6
bob4703
1974 CJ5
Engine! Simpler, cleaner, and quicker unless you have a lot to remove or disconnect before you remove engine.
If it has rollup windows and A/C it ain't a Jeep. It is a rebranded Dodge!
bob4703 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 07:30 AM   #7
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hmm...it never occurred to me to pull the engine to replace a clutch.
That seems like a LOT of extra work to me.
Here's how I do it:
1. Support the engine.
2. Disconnect the rear driveshaft at the t-case.
3. Stick my rolling jack under the skid plate and remove the bolts holding the skid to the frame.
4. Remove the bolts holding the transmission to bell-housing.
5. Slide transmissiont/t-case/skid rearward as one unit until the input shaft clears the bell.
6. Remove bell-housing, replace clutch parts, and reassemble.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 08-16-2015, 08:51 AM   #8
Pathkiller
1974 CJ5
I would never pull an engine for a clutch job. Dropping the transmission and transfer case is a lot easier in my opinion.
74 CJ5 complete frame off restoration
Pathkiller is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 08:55 AM   #9
jeepdaddy2000
1971 CJ5
I too am a supporter of pulling the motor. It gives you a chance to check a couple of other things, such as hoses, motor mounts, clutch linkages, and makes re installation much easier as well. The only real issue can be the exhaust.
Of course, both methods hinge on having the proper tools. If you can get the Jeep up and can actually sit under it, removing the transmission isn't a bad option. Not having an engine hoist can hamstring the engine removal.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 09:06 AM   #10
Matt1981CJ7
1981 CJ7
Yep. And if you use the method I described above, you don't actually "drop" anything to the ground. You just slide it all rearward.
The transmission and t-case stay attached to each other, and the skid acts like an out-rigger to prevent the assembly from rolling over off the jack. It really does work slick.
Matt
Unread 08-16-2015, 09:38 AM   #11
Jon In Tucson
Jesus Is Lord!
Jon In Tucson's Avatar
1983 CJ5
Originally Posted by 1980tallcj7 View Post
Hey y'all,
Perfectly timed thread for me! I have the same issue as you have 1980, the throw out bearing make an awful noise when the pedal is depressed. If I go to the trouble of dropping the transmission and transfer case for a bad throw out bearing, I would be crazy not to do the rest of the clutch components while apart.
What kind of area do you have to perform the job? I don't have a garage, but I do have a nice smooth slab of concrete in the back yard. That will make using the floor jack and stands easier.
I like Matt's description of the steps to remove the parts to access the clutch components.
However, I understand Mike's concern regarding skid plate bolts becoming a solid rusted mass.
Here in sunny AZ not so much of a worry. My worry is that a pack rat will have made his nest in the recess of the skid plate and jump out as I am loosening it and startle me enough to bang my head on the frame... After it cools off a bit, (under 100*) I'm going to tackle this chore. So far as I have priced out the parts, LUK clutch kit is very reasonable from Rock Auto even with shipping. Our local Pep Boys has the LUK kit for about $50 more. While you're in the clutch that deep, its a good time to resurface/replace the flywheel and look at the starter ring. I just replaced the starter recently and will be giving the starter ring a close inspection. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 09:44 AM   #12
Matt1981CJ7
1981 CJ7
Jon,
I forgot one step.
Before you slide the transmission/t-case/skid assembly rearward, be sure to disconnect the speedo cable, 4x4 indicator, and reverse light wiring.
Matt
Unread 08-16-2015, 07:25 PM   #13
1980tallcj7
1980 CJ7
Originally Posted by Matt1981CJ7 View Post
Jon,
I forgot one step.
Matt
Ummm, didn't see any mention bout the front driveshaft, of shifters either
1980 CJ7, Mule
Unread 08-16-2015, 08:35 PM   #14
jeepdaddy2000
1971 CJ5
LOL
you have never tried to install a clutch in an early Bronco
Unread 08-16-2015, 10:22 PM   #15
CSP
The transmission and tcase can be out faster than the fluids drain and engine wiring is disconnected IMO.
CSP is online now   Reply With Quote Quick reply to this message
