Which fan will fit? - JeepForum.com
post #1 of 9 Old 06-09-2013, 07:56 PM Thread Starter
burley
1976 CJ5
Which fan will fit?
PO put in a new radiator which is larger than stock it looks like. I'm measuring about 2.5" of room behind the radiator and 2.75 in front.
I was planning on getting a ford torus/contour/mk VIII fan but now wonder if theres room. Why would you replace a radiator and not a fan? In Arizona? Can you a Jeep without a fan??
Ideas?
burley is offline
post #2 of 9 Old 06-09-2013, 08:07 PM
WindKnot
1977 CJ7
Was there a fan that you removed? Why do you want to install an electrical fan?
If there was a four bladed solid mounted fan with no clutch there, that was stock. Not even a shroud.
I'm in Arizona and I'm still running the stock cooling system with no problems whatsoever. It can sit all day and idle or drive across the desert with not a smattering of overheating.
This is stock, and yes the fan is close.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 9 Old 06-09-2013, 08:18 PM Thread Starter
burley
1976 CJ5
This is how I got the Jeep. I've removed nothing, and the only reason I assume the fan won't fit is because there's not one there now. Thats the only reasonable scenario I could imagine the PO not having one on. If a stock fan will fit, great! I just assumed that I'd have to mound an electric fan on the other side because there's slightly more room.
From my service manual, it looks like I'm just missing a 4-blade fan and spacer, right?
burley is offline
post #4 of 9 Old 06-09-2013, 09:26 PM Thread Starter
burley
1976 CJ5
And no fan clutch was used on the 258 in '76? Just in the 304 and 258s after '81?
burley is offline
post #5 of 9 Old 06-09-2013, 09:46 PM
WindKnot
1977 CJ7
CJs in '76 did have a heavy duty cooling package available, and it was available for a 258. Most base model Jeeps didn't have it and it doesn't look like yours did either. If your Jeep had A/C, it had the HD cooling system.
The heavy duty had a shroud, a three row radiator, fan clutch and a seven bladed fan.
The standard didn't have a shroud or fan clutch, a two row radiator and a four bladed fan.
Here is a link to the 1976 Jeep Technical Service Manual: http://oljeep.com/edge_76_tsm.html
Some guys put the Ford Contour electric fan in theirs. I have a base Jeep with the 258, run the stock cooling system and it sits at 190° all day long.
WindKnot is offline
post #6 of 9 Old 06-09-2013, 09:56 PM Thread Starter
burley
1976 CJ5
I don't plan on doing heavy offloading, so stock sounds fine to me. Would it be worth it to spend the extra $35 on a fan clutch now, considering it fits?
burley is offline
post #7 of 9 Old 06-18-2013, 11:29 PM Thread Starter
burley
1976 CJ5
I just installed a 4 blade fan from morris 4x4, and it rubs on the belt. It looks like there's a spacer that needs to be installed, does anyone have a part number?
burley is offline
post #8 of 9 Old 06-19-2013, 02:05 AM
LeePrather
1978 CJ5
I went to the closest auto parts store and told them I needed a 2" spacer and they had it...pretty sure that's a generic thing...
LeePrather is offline
post #9 of 9 Old 06-19-2013, 06:57 AM Thread Starter
burley
1976 CJ5
Ahh, thanks! I'm such a novice its not funny.
burley is offline
