-   -   Which fan will fit? (http://www.jeepforum.com/forum/f8/fan-will-fit-1534430/)
burley 06-09-2013 07:56 PM
Which fan will fit?
3 Attachment(s)
PO put in a new radiator which is larger than stock it looks like. I'm measuring about 2.5" of room behind the radiator and 2.75 in front.
I was planning on getting a ford torus/contour/mk VIII fan but now wonder if theres room. Why would you replace a radiator and not a fan? In Arizona? Can you a Jeep without a fan??
Ideas?
WindKnot 06-09-2013 08:07 PM
Was there a fan that you removed? Why do you want to install an electrical fan?
If there was a four bladed solid mounted fan with no clutch there, that was stock. Not even a shroud.
I'm in Arizona and I'm still running the stock cooling system with no problems whatsoever. It can sit all day and idle or drive across the desert with not a smattering of overheating.
This is stock, and yes the fan is close.
http://i1116.photobucket.com/albums/...s/DSCN0295.jpg
burley 06-09-2013 08:18 PM
This is how I got the Jeep. I've removed nothing, and the only reason I assume the fan won't fit is because there's not one there now. Thats the only reasonable scenario I could imagine the PO not having one on. If a stock fan will fit, great! I just assumed that I'd have to mound an electric fan on the other side because there's slightly more room.
From my service manual, it looks like I'm just missing a 4-blade fan and spacer, right?
burley 06-09-2013 09:26 PM
And no fan clutch was used on the 258 in '76? Just in the 304 and 258s after '81?
WindKnot 06-09-2013 09:46 PM
CJs in '76 did have a heavy duty cooling package available, and it was available for a 258. Most base model Jeeps didn't have it and it doesn't look like yours did either. If your Jeep had A/C, it had the HD cooling system.
The heavy duty had a shroud, a three row radiator, fan clutch and a seven bladed fan.
The standard didn't have a shroud or fan clutch, a two row radiator and a four bladed fan.
Here is a link to the 1976 Jeep Technical Service Manual: http://oljeep.com/edge_76_tsm.html
Some guys put the Ford Contour electric fan in theirs. I have a base Jeep with the 258, run the stock cooling system and it sits at 190 all day long.
burley 06-09-2013 09:56 PM
I don't plan on doing heavy offloading, so stock sounds fine to me. Would it be worth it to spend the extra $35 on a fan clutch now, considering it fits?
burley 06-18-2013 11:29 PM
3 Attachment(s)
I just installed a 4 blade fan from morris 4x4, and it rubs on the belt. It looks like there's a spacer that needs to be installed, does anyone have a part number?
LeePrather 06-19-2013 02:05 AM
I went to the closest auto parts store and told them I needed a 2" spacer and they had it...pretty sure that's a generic thing...
burley 06-19-2013 06:57 AM
Ahh, thanks! I'm such a novice its not funny.
The time now is 10:28 PM.
