Fan shroud - JeepForum.com
post #1 of 5 Old 02-04-2010, 04:22 AM Thread Starter
SonicR1
Fan shroud
I was working on my engine today and noticed that the bottom part of the fan shroud was missing, is this normal for a 304??? This can't be right!!! I am thinking the PO had a body lift on this and cut the shroud instead of remounting it...
Picasa Web Albums - William - 1974 CJ5
Any thoughts?
hmmm, maybe I will be replacing the fan with the Countor electric fans sooner than I thought...
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #2 of 5 Old 02-04-2010, 08:49 AM
h2ojeep
1978 CJ7
It is hard to tell from the angle of the photo, but it appears that the outer diameter of your fan does not match the inter diameter of the shroud, the fan seems too low.
Does your jeep have a Body lift? On body lifts, the engine stays at the same level while the radiator and fan shroud move up in relation to the engine and fan. Is it possible that the PO put a body lift in and removed the bottom part of the shroud to avoid hitting the fan? I am about to put on a body lift but plan to keep my shroud and move it lower to match the lift. Others who do body lifts simply remove the shroud but risk having cooling problems.
Do you have any cooling issues?
h2ojeep is offline
post #3 of 5 Old 02-04-2010, 05:16 PM Thread Starter
SonicR1
Yeah, it looks like it had a body lift on it and the guy took it off. But why wouldn't you just use the relocation brackets that come with most body lifts??? I don't know if it overheats because I am in the process of getting it running. I just wanted to confirm that the stock shroud is like all shrouds, and it basically surounds the fan.
SonicR1 is offline
post #4 of 5 Old 02-04-2010, 05:57 PM
retrofit9
1979 CJ7
PO cut the shroud fo sho
retrofit9 is offline
post #5 of 5 Old 02-05-2010, 09:56 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Because they don't all come with them. Many CJ's didn't receive shrouds in the first place.
When you are almost done with an install job (like a lift) and you run into an annoying interference like that, wrapping up the job incorrectly will sometimes yield a high degree of satisfaction.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
Fan Shroud-Help! Rocket6R Jeep CJ Forum 27 07-20-2009 09:25 AM
Fan shroud Q's 4wheelinfool Jeep CJ Forum 3 11-16-2008 04:00 PM
Looking for Fan Shroud for 84 CJ-7 with GM 350 jbramble24 Jeep CJ Forum 1 03-09-2008 10:49 AM
Fan Shroud anyone... longlimb Jeep CJ Forum 10 05-05-2006 06:18 PM
Where can I get a Fan Shroud??? Boots Jeep CJ Forum 4 07-26-2002 11:37 AM
