fan shroud - Page 2 - JeepForum.com
post #16 of 19 Old 06-12-2013, 03:55 PM
Balvar24
1979 CJ7
Originally Posted by neal90 View Post
not sure what the temp gets up to numerically but the temp gauge gets almost all the way to the right
Are you sure it's working correctly? There's a reason they were made without numbers.
Mine goes ALL the way to the right. My mechanical gauge never gets above 190. I can watch it and tell when the thermostat is open/closed.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #17 of 19 Old 06-12-2013, 04:02 PM
LumpyGrits
Your temp readings also depends on where the sensor is>
LG
LumpyGrits is offline
post #18 of 19 Old 06-12-2013, 08:25 PM
Spieg8
1984 CJ8
and how do you back flush
Install a kit like this so you can hook up a garden hose to your cooling system;
http://www.oreillyauto.com/site/c/de...kit%21s%21test
Then add something like this to the system and follow the directions;
http://www.oreillyauto.com/site/c/de...radiator+flush
Do this before you pull the radiator to have it boiled out (you want to boil out any debris that may be dislodged by the flush process).
This followed by filling with fresh antifreeze and distilled water should help your system a lot.
Spieg8 is online now
post #19 of 19 Old 06-12-2013, 08:45 PM
LumpyGrits
You have to remove the t'stat to back flush.
Rod-out is the best thing for a brass radiator.
Good coolant and add distilled water as needed.
Don't use 'tap' water because of the chems in it.
LG
