fan shroud - JeepForum.com
post #1 of 19 Old 06-11-2013, 06:04 PM Thread Starter
neal90
1982 CJ7
fan shroud
getting a little confused about what fan shroud i need. So i took some pics to help out thanks
The one that is labeled as center cap on morris 4x4 just looks like the opining is to small
neal90 is offline
post #2 of 19 Old 06-11-2013, 06:09 PM
only in a jeep cj
You have an OEM style 3 core replacement radiator with a fixed 4 blade fan and spacer. No shroud needed.
As a general rule, the 5 and 7 blade fans that have fan clutches use the shrouds.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 19 Old 06-11-2013, 06:15 PM
skizriz
1978 CJ7
That's the same setup I have with no shroud, and the highest temp I have ever seen was 205 while wheeling on a 95* day. It normally runs about 170.
Are you having cooling problems?
skizriz is online now
post #4 of 19 Old 06-11-2013, 06:36 PM Thread Starter
neal90
1982 CJ7
driving on the beech with very fine sand and the jeep starts to ever heat after 15-20 min
neal90 is offline
post #5 of 19 Old 06-11-2013, 07:23 PM
gojeepgo
1981 CJ7
A few years back I had a problem finding one. I ended up getting one through OK4WD. I called and spoke with Mike and he helped me out. Give a call. Maybe he can find the right one for you.
gojeepgo is offline
post #6 of 19 Old 06-12-2013, 07:34 AM
WindKnot
1977 CJ7
As the others already said, your Jeep didn't come from the factory with a shroud. How warm is overheating? 258s run fairly warm. Mine goes all day at 190°.
Are you saying the sand clogs the radiator?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 19 Old 06-12-2013, 10:38 AM Thread Starter
neal90
1982 CJ7
not sure what the temp gets up to numerically but the temp gauge gets almost all the way to the right
neal90 is offline
post #8 of 19 Old 06-12-2013, 10:41 AM
LumpyGrits
Rod-out the radiator.
After that, use distilled water only with coolant.
LG
LumpyGrits is offline
post #9 of 19 Old 06-12-2013, 11:07 AM
jumbojeepman
1976 CJ7
Let more air out of your tires. When you've let out enough, you should be able to run in 4-hi with no overheating. Try somewhere between 10-12 psi.
jumbojeepman is offline
post #10 of 19 Old 06-12-2013, 11:41 AM Thread Starter
neal90
1982 CJ7
how do you "rod-out a radiator"????
neal90 is offline
post #11 of 19 Old 06-12-2013, 11:42 AM
Spieg8
1984 CJ8
I agree with LumpyGrits. Do some maintenance to the cooling system. I'd do a good back flush of the entire cooling system. Probably replace the thermostat too (they're cheap). I've been running my CJ for 20+ years without a shroud and never come close to over heating. Even out at Sand Dunes National Monument in August (read sand, heat and altitude), my temp gauge stays close to the middle.
Spieg8 is offline
post #12 of 19 Old 06-12-2013, 11:43 AM Thread Starter
neal90
1982 CJ7
and how do you back flush
neal90 is offline
post #13 of 19 Old 06-12-2013, 11:59 AM
titomars
1981 CJ7
Even if you wanted to install a shroud as long as that cooler is strapped to the back side of the radiator it would not fit.
a fan shroud will not solve your heating problem in my opinion. You have other issues going on there. I had the same set up as you and my gauge never moved more than a needles width once it reached running temp.
Here are a few things to check:
Check your timing if its too retarded that will run the engine hot as Hades.
thermostat might not be working right or stuck or missing.
A missing t/stat will run an engine hot due to coolant flowing too fast through the rad.
Radiator plugged or partially plugged.
loose belts.
lower radiator hose collapsing.
water pump Failing.
Bad sender or gauge. (only telling you its hot but not really)
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #14 of 19 Old 06-12-2013, 12:40 PM
LumpyGrits
Take the rad. to a pro shop to do a rod-out.
Google is your friend....
http://www.aceradiator.com/faqs.htm
LG
post #15 of 19 Old 06-12-2013, 01:43 PM
WindKnot
1977 CJ7
^^^I agree^^^ Most likely cheaper than a new radiator and you'll probably have a better product.
WindKnot is offline
