Fan got into radiator? - JeepForum.com
post #1 of 17 Old 05-03-2010, 02:19 PM Thread Starter
jds79cj
I'm sure some of you have seen my build thread if not here is the link for the most information on my Jeep CJ5.
http://www.jeepforum.com/forum/f22/7...ml#post9397390
As you can see I finally got it back together and took it for its first trail ride this weekend. Other then very crappy gear ratio of the T150, Dana 20 and 3.54 gears it did pretty good.
I spent the first day just shacking it down making sure everything was ok didn't really tackle anything difficult. On Saturday I decided everything check ok so I started doing some harder climbs. It did awesome until I tried climbing a rock ledge and the front wheels came off the ground about 2-3". Some how even though I started with over an inch of clearance from the radiator to fan the two met and the fan ate up the radiator.
I can not find what flexed and allowed the fan to get into the radiator, nothing is wrinkled in the front and I still have 1" of clearance. The body, motor and transmission mounts are all new and every thing is still tight. Does anyone have an idea what I need to do to keep the fan out of the radiator this was a brand new 3 core radiator I really don't want to another in it and have this happen again.
jds79cj is offline
post #2 of 17 Old 05-03-2010, 02:24 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
when my motor mounts gave, I lost a radiator. You might check there first.
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #3 of 17 Old 05-03-2010, 02:26 PM Thread Starter
jds79cj
Mounts are brand new Moog it was the first weekend out with them!
jds79cj is offline
post #4 of 17 Old 05-03-2010, 02:33 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
bummer, next leads to front clip flexing, how are the body mounts?
Truck633 is offline
post #5 of 17 Old 05-03-2010, 02:35 PM Thread Starter
jds79cj
Brand new body mounts also!
This is why I am so baffled I can not find what flexed to allow the fan to move close to 1" and get into the radiator.
jds79cj is offline
post #6 of 17 Old 05-03-2010, 02:50 PM
petey156
when i had the factory fan on my 258 there were 2 inches between the raved it pretty hard and diator and fan but one day i renow there is a swirrel mark in the radiator. soon after that i went for an electric fan not problems since.
petey156 is offline
post #7 of 17 Old 05-03-2010, 02:59 PM Thread Starter
jds79cj
I am leaning towards a electric fan my self, did you put a temp sensor or did you just run the fan all the time?
jds79cj is offline
post #8 of 17 Old 05-03-2010, 03:24 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Happened to me too. Actually I lost a driveshaft which either broke the motor mounts or allowed the engine to jump forward since they were already broken.
When I put it back together (had to get a new radiator), I moved my radiator deeper inside the front clip because there was VERY little room, especially with the aftermarket radiator.
I have an electric fan in my new CJ, which seems better all around.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #9 of 17 Old 05-03-2010, 03:30 PM
syn
I've had that happen twice to me, mind you the first time the engine mounts weren't properly secured and there was half an inch clearance at best. The second time I have no idea what caused it, but to fix my problem I put the radiator on the inside of the grill flanges (I have a 7 so I'm not sure how the mounting differs from your 5). I now have about a solid inch of clearance and I'm going to space it out further this summer.
I am thinking about going to an electric fan though...much less of a hassle. But here's a tip, buy a new radiator from autozone with a lifetime warranty! When I originally bought my CJ and replaced the only radiator I bought a new one from autozone and both times I have butchered it (it was very clear my fan ripped it apart) they took it and gave me a brand new one NO QUESTIONS ASKED.
Gotta love lifetime warranties.
syn is offline
post #10 of 17 Old 05-03-2010, 03:57 PM
CJ8Ted
1985 CJ8
I did the very same thing. I upgraded to a three row core rad, the third row being on the inside. The first time we gave it a real workout "Grrrrrrr" fan cluch into 6 month old rad. It did not leak at the swirl mark so I ran it for the last eight years. I went to an electric fan on a thermostat (in cab cut off switch) I also added another fan between the grill and rad for the hot days at 2mph on the trail, I just wired that with a switch under the hood.
As for flexing, everything flexes the body, frame, motor mounts, everything. The next thing you know the inch of clearance is not enough. If it is close you could try turning the grill surport rods out to the max length
Ted
1985 CJ8 on 33s W/ 4.56s
CJ8Ted is offline
post #11 of 17 Old 05-03-2010, 11:38 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I was thinking that the grille rods bowed, allowing things to move. They do seem kinda flimsy.
Rick
Cutlass327 is offline
post #12 of 17 Old 05-04-2010, 03:20 AM
trw
2011 JK Wrangler
I noticed the OEM radiator in my CJ was badly damaged in a circular pattern as if the fan hit it (this is with a V8 too, not the I6).
I never understood how this could happen unless the mounts sheered
is it possible the motor mount bushings and tranny mount allow some forward movement? (I haven't looked at them on my CJ yet, dont know if they are different from my YJ).
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #13 of 17 Old 05-04-2010, 05:38 AM
gmakra
I have to concur with Cutlass the grille support rods maybe bowed. The location of the radiator make for a very cozy relationship with the fan blades. Also if the grille was removed and reinstalled the six bolts that tie the grille to the fenders have a decent amount of play in them and could installed to far back.
I would also suspect the fan clutch when I replaced mine it seemed that it was slightly larger and moved the fan toward the radiator.
One thing I did was install the radiator on the front side of the flange in the grille which gave me maybe a 1/4 inch more room.
gmakra is offline
post #14 of 17 Old 05-04-2010, 06:55 AM
Happy Joe
The radiator mounts (inner grill) on my 5 were very flexible and let the radiator get pushed into the fan once during a session of water wars/soak the passengers (a couple of pieces of angle stiffened it up).
The other times that I trashed radiators were either due to motor mount or transmission mount failure.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #15 of 17 Old 05-04-2010, 08:59 AM Thread Starter
jds79cj
Looking at all possibilities of what caused this tells me the one sure cure is to get a electric fan set up and ilimnated the motor mounted fan. I was looking last night at Advance Auto and they have a 16" fan for $79 and adjustable fan controller w/ fuse and relay for $34 that is a heck of a lot cheaper then a new radiator so I guess I'll go that route.
Thanks for all replies!
jds79cj is offline
Radiator HELP!!! cgi2099 Jeep CJ Forum 11 01-24-2010 01:11 PM
Radiator Hoses for AMC 360 to CJ Radiator Rollbar Jeep CJ Forum 2 04-18-2009 11:45 AM
radiator for v8 77cj5sea Jeep CJ Forum 1 04-04-2009 10:59 AM
Which radiator NWA_CJ7 Jeep CJ Forum 5 04-02-2009 09:51 PM
Do I need a Chevy Radiator or a Jeep Radiator? brice1310 Jeep CJ Forum 8 04-19-2007 07:46 PM
