Failure mode of T5 backup light switch - JeepForum.com
post #1 of 8 Old 10-09-2015, 06:30 AM Thread Starter
rbunch4468
1983 CJ5
I've searched without success on this 'one off' question about the backup light switch. My switch will work if it is removed from the tranny, but it seems to take a long 'throw' to make connection. I am not getting continuity when it is installed with the transmission in reverse. Is the failure mode of these usually work/don't work... or can you see wear causing the switch to require more stroke than when new? This has worked previously in this transmission. I would think the internal transmission trip mechanism is more robust than the switch. I am just about to wire in a workaround by mounting a microswitch at the base of the shift lever, but thought I would ask about this. I need backup lights to pass my state inspection this month. Thanks
rbunch4468 is offline
post #2 of 8 Old 10-09-2015, 08:22 AM Thread Starter
rbunch4468
1983 CJ5
OK... a little different observation this morning. I was able to connect the meter to the switch so I could watch the dial as I moved the shifter from the cab. The switch works. The shifter over travels through the switch detent in reverse. I can shift into reverse, the switch connects... then I can move the shifter another little bit to a hard stop past the switch detent. Does anyone know of an adjustment for either the switch detent or the hard stop of shifter travel into reverse?
post #3 of 8 Old 10-09-2015, 09:27 AM
only in a jeep cj
Sounds like there might be a wear point in the reverse lever which activates the ball socket at the end of the reverse switch. Maybe worth a try is to remove the switch and place s thin washer as a shim between the switch and the transmission body to see if changing that just a little can make it stay on at full lever range
At the same time see if you can visually look into the hole while in reverse to see if the reverse bar is over extended past the switch ball causing the the loss of contact
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 8 Old 10-09-2015, 09:43 AM
turkish6
1982 CJ8
I had the same issue with my T4 switch. Worked when removed but no lights when installed. Was advised by members here to soak the switch in WD-40 to clean up any corrosion. But I had no luck.
Replacing the switch fixed the issue.
turkish6 is online now
post #5 of 8 Old 10-09-2015, 11:07 AM
LumpyGrits
Cj
I've lost count of how many BU switches I have bought over the last 30 yrs for my T-5.
Buy several and have spares on hand, or go to a manual BU switch.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 8 Old 10-09-2015, 11:46 AM
turkish6
1982 CJ8
Mine went bad within 1 year
post #7 of 8 Old 10-09-2015, 01:21 PM Thread Starter
rbunch4468
1983 CJ5
Rigging up a micro switch to detect the shifter base position now. I will work back from the transmission wiring harness connector and run the repair from there. Once I pulled up the oily pair of wire back up into the engine bay, I could tell a lot better what was connected to what, and where the best place to tie in would be. The PO cobbled together a mess off of the back of the harness connector. Will take pix and post tonight when this is done. Pretty straightforward stuff, but maybe it will help someone.
post #8 of 8 Old 10-09-2015, 03:51 PM Thread Starter
rbunch4468
1983 CJ5
Back together and it works. Inspection tomorrow. No Pix tonight, as rain has moved in, and I am doing this in the driveway... jealous of neighbors with garages at time like these!
