failing at the low tech approach - JeepForum.com
post #1 of 12 Old 04-26-2013, 07:04 PM Thread Starter
geneapodaca
1978 CJ7
When I bought my beat-up '78 CJ7, I wanted a V-8, which I got and something not needing a bunch of work which I didn't get. I ended up replacing the engine, rewiring the vehicle from the parking lights to the backup lights, replacing a bunch of seals, gauges, and interior parts and eventually a new top too. All good fun.
Starting out, I was determing to stay low tech so the jeep would remain field repairable as much as possible. I figured this approach would allow me to get it home no matter where I was using minimal spare parts, a roll of baling wire and some electrical tape.
I bought rebuilt distributors from the local shop and managed to keep one just past the warranty period before it started acting up. After the 2nd one failed, I decided to go new.
Sooo, yesterday I installed a DUI distributor from Performance Distributor along with a set of Hotwires from Nology. Woohoo, does this engine run sweet!! The torque at idle is mindblowing and acceleration throughout the range is noticeably better. Maybe I can live with the enhanced reliability and performance of higher tech instead of field repairability. Hmmmm
geneapodaca is offline
post #2 of 12 Old 04-27-2013, 06:46 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You'll be fine...
At least until North Korea blows an EMP burst over us.
John Strenk is offline
post #3 of 12 Old 04-27-2013, 07:00 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Without pictures, it's all just gum-flapping.
Matt
Matt1981CJ7 is offline
post #4 of 12 Old 04-27-2013, 07:20 AM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Matt
Well, finger flapping technically.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #5 of 12 Old 04-29-2013, 11:09 PM Thread Starter
geneapodaca
1978 CJ7
Forums by definition are finger flappings. I can show you pictures but nothing proves the vehicle is mine. I'm sure I could find a few pics on the internet even. If you live in New Mexico, I'll show it to you. Otherwise, you can just wonder if I'm being honest or not.
post #6 of 12 Old 04-30-2013, 12:01 AM
mvbrady
Let the conversion begin...it only gets better.
Next time your in Farmington... you can show me and I can vouch for you....that should be better than your avg. web pic
mvbrady is offline
post #7 of 12 Old 04-30-2013, 12:10 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
You don't think an HEI is "field repairable"?
Doesn't get much easier to repair than that, nor easier to find parts for.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #8 of 12 Old 04-30-2013, 09:05 AM
scrapman
You'll be fine...
John,
In all seriousness, wouldn't the hood of the vehicle protect the electronics of the car's engine from an EMP? Or would the only cars running after an EMP be those with the old points ignition?
scrapman is offline
post #9 of 12 Old 04-30-2013, 11:08 AM
John Strenk
1976 CJ5
The hood doesn't seem to block the electronic emmisions coming out of my CJ, hard think they would block anything coming in.
There already is a EMP cannon designed to stop cars. http://www.popsci.com/technology/art...wer-next-month
Points are practically fool proof when it comes to stuff like that. or Just another reason to go diesel....
Like I really need one.
post #10 of 12 Old 04-30-2013, 11:38 PM Thread Starter
geneapodaca
1978 CJ7
The distributor can easily be maintained but I was talking about something catastrophic like an EMP which would completely cook the internal electronics. That can't be field repaired without a whole new distributor, or at least a complete spare set of everything electric internally. And, the spares would have to be stored so they don't get cooked too. Cars aren't really EMP shielded at all. My job is military aircraft electronics systems and I understand the differences. It's not impossible to partially protect most vehicle electrics but it's costly and really not worth the trouble unless you really want your jeep to survive a monstrous solar flare or high altitude nuke. The weak areas are the control modules which can be shielded by wrapping them completely in a metal screen (either fine mesh or solid box) which is thoroughly grounded but the wires going in and out of them also have to be shielded which is the tricky part. Shielded wiring (kind of like standard TV cable wiring) is required to do that and that's the expense. The center carries the voltage and the shield part has to be grounded at both ends of any wire that can possibly connect into the control module wires. The alternators would probably fry too but starters might make it.
MvBrady; I'm in Albuquerque and venture north all the time but don't often hit that corner you're in. I'll let you know next time I do though. Wanna meet me in the Jemez mountains Memorial weekend? I'll be there starting Friday afternoon all weekend.
post #11 of 12 Old 05-01-2013, 08:21 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
First off, an EMP will never happen, so it's really irrelevant.
But, IMO the only thing in an HEI that would possibly be damaged is the module. So carry another one. They're cheap. And it's not likely to be damaged in the first place. You'd have to be at the exact right place at the right time for any damage to occur.
There's no such thing as an EMP detonating over the US and the whole country going dark. That's not the way it works.
Jimmy V
post #12 of 12 Old 05-01-2013, 11:19 AM
mvbrady
Thanks for the invite....already planning to take the Kids Camping at Navajo lake....another time,
Have a Great Holiday weekend.
mvbrady is offline
