Factory wiper delay switch - JeepForum.com
post #1 of 8 Old 08-26-2013, 05:28 PM Thread Starter
smokedog
Trying to finish up my restoration project and have factory delay wipers. I have all of the wires and the black box but not the switch that mounts in the dash. I can't find it anywhere! Does anyone have an extra one they would sell or can you tell me if in fact a switch from an early 80's truck will work?
Smokedog - Brandon, MS
84' CJ7 Renegade - Tungsten grey metallic paint, 388ci Chevy, 700r4, D300, SOA lift with YJ springs, 1" body lift, Bilstein 5150 shocks, Currie Rock Crawler Shackles, Trussed Ford 9 Rear w/ 4:56 gears, Detroit lockers, Dana 44 front, full poison spyder cage and lots of chrome and stainless.
smokedog is offline
post #2 of 8 Old 08-28-2013, 08:09 PM
keith460
Jeep. There's Only One
keith460's Avatar
I was able to buy one from NAPA a few years back. I imagine they can still get them.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 8 Old 08-28-2013, 08:40 PM
titomars
1981 CJ7
Go to Pick A Part and look for any 78 to about 87 Ford full size pickup truck with intermittent wipers. they are the same switch and same module/wiring harness.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #4 of 8 Old 08-28-2013, 08:48 PM
JrTjK
1978 FSJ Wagoneer
I have a few NOS ones but they're either sitting in my reserve, or being held as samples...trying to get them reproduced, but who knows if it'll happen.
JrTjK is offline
post #5 of 8 Old 08-28-2013, 09:00 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
I believe the wiring is slightly different on the Ford version.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #6 of 8 Old 08-28-2013, 09:28 PM
titomars
1981 CJ7
the switch is the same which is what the OP was after. The wiring is is the same but color coding is different. Also the Ford has one extra Wire in the module harness which is not needed for us CJ'ers.
titomars is offline
post #7 of 8 Old 08-28-2013, 11:25 PM
BlkCJ7Laredo
Does anyone have any rock solid evidence of this? With a fair amount of searching it looks like unless you swap some wires the windshield washer won't work with the Ford parts. Also some other sources say the hole the switch passes thru is a different diameter, requiring modifications.
If it were truely that easy, the switches for the Fords are readily available thru the aftermarket for about $45 each
post #8 of 8 Old 08-28-2013, 11:57 PM
titomars
1981 CJ7
First off I don't use the washer circuit so I can't speak about that. but I am using an 86 CJ module with a Ford switch in my 7. Works fine for me. I did not have to do any mods to fit the switch into the dash. I even used the stock CJ nut and bezel. Only mod I had to do was connecting the module/harness into the dash harness. Mine was a 3 wire 2 spd from the factory. I also dewired the washer circuit from the module/harness.
When I was at the wreckers I grabbed 3 or 4 switches and modules out of early 80's Fords.
I do believe the 89 on switches are physically different in shaft length and mounting size.
titomars is offline
