Factory swing away tire carrier bolts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Factory swing away tire carrier bolts?
Poison Spyder from CCOR!8.8 Swap Kit w/ TRUSS for JeepsDana 30 Truss for your TJ, LJ, ZJ, and XJ
Unread 09-11-2010, 08:28 AM   #1
mikeumkc
mikeumkc's Avatar
2009 JK Wrangler
I just got this CJ and it did not have the tire carrier installed, just had it sitting in the back. It has all the brackets and everything on the body, ready to go. I just have to bolt it on the hinges.
My question is, what kind of bolts do I need to use? Anything specific to make sure it swings ok?
2009 JKU Rubicon. stock now.... I'm working on it.
mikeumkc is offline   Reply With Quote
Unread 09-11-2010, 09:10 AM   #2
only in a jeep cj
The OEM bolts are a bit different than the common hardware store bolts as in they have a wider than normal shoulder that extends down through the brackets. Although any bolt will do, if not the correct fit, the vibration and movement will elongate the holes and the rack will rattle a lot. Body stress cracks could also form as a result of the rack moving around.
After 200 thousand miles, mine was loose and the holes slightly ovaled, I redrilled one size up and used a set of bolts out of a YJ that had the shoulder length I needed. Then I measured and cut off the extra.
OEM bolt
New bolt before I cut it.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 09-11-2010, 09:53 AM   #3
keith460
Jeep. There's Only One
keith460's Avatar
Factory OEM bolts are 7/16-14 x 2-1/4"L but are special because the length of shank part of the bolt is 1-3/4"L so the threaded portion is not through the hinge bracket. You could purchase 7/16-14 x 3"L bolts and cut off the excess threads since the shank part of those bolts @ 1-3/4" are long enough to pass through the hinge bracket.
I was able to find 7/16 diameter S.S. Shoulder bolts like 20 years ago for mine and they work great and won't rust. Photo below is what I use.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 09-11-2010, 12:27 PM   #4
mikeumkc
mikeumkc's Avatar
2009 JK Wrangler
thank you so much guys. I'll head to the hardware store and see what I can find.
