#1 | |
factory 4:56 wide track?
did the factory have a 4:56 wide track with a trac-loc with a code of GG going to look at a set over thanksgiving Guy said its a wide trac GG code is a factory 4:56 with a trac-loc...
can you use a one piece axle with factory trac-loc any help would be wonderfull
Life's to short to be stuck behind a desk! |
#2 |
GG is the code for 3.73 ratio open diff. I don't believe 4.56's were offered from the factory. One piece with Trac Lok is nt a problem.
#3 |
GG is a narrow track 3.73 Wide track is a HH for 3.73 with trac-loc
#4 |
you don't want the trac lok anyway.......
#5 |
Why not Trac-loc for a daily driver with mild off road?
#6 |
They are junk. And I don't mean just offroad. The wear out, fall apart, split, shed clutch keepers, and are, in my opinon, worse than an open diff.
just my unbiased .02...... |
#7 |
Thanks for your opinion need to look more into them it sounds like. can they be converted with our replaceing the center section?
#8 | |
1. You can't use 1 piece axles. 2. The Trac Lok case itself is a weakness. Last edited by 80cj; 11-21-2009 at 11:02 AM.. |
#9 |
So if im thinking right just need to remove the trac-lock and install a ARB LOCKER and be done with it, If they are 4.56
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
